ADVERTISE HERE - FREE TRIAL
Colored pencil turning
Clyde Collier
Some time back someone showed a picture of a turning using colored pencils. I'm interested in finding out how the pencils are held together so I can turn a piece for my wife. Thanks for the help.
Re: Colored pencil turning
Is this what you are after? *LINK*
Keith Newton
Just put colored pencil in the keyword search, then wala.
If I were doing this, I would mix epoxy, and pour it out on some foil, or even a scrap of mdf, then take a handful of pencils and lay the whole bunch out on top, and with a gloved hand roll the bunch back and forth until they were all coated. Drop those into a solo cup and do the next bunch, until they are all coated. As slippery as epoxy is, they should all seek alignment, and even if they don't, there would be plenty of time to fool with them until they were.
A couple of rubber bands would be all you need to hold them together, and it should only take a couple of minutes to glue the whole thing. Although the epoxy would need to wait a day to cure.
http://www.woodcentral.com/woodworking/forum/turning.pl/pro/search/pmd/sread/srchid/1210TG7NG4jtAW67F861414764847/spage/1/sanc/480724/sbid/2000/md/read/id/480718/sbj/this-is-what-i-made-out-of-126-colored-pencils/
Bill Jacksonville, NC
I had my doubts about using CA glue, after reading Jim K’s post here see no problem with his procedure or results.
If do a google search will see many example color pencil turnings guess the strongest held together by resin but some are glued together with wood glue too. If click on a picture may find nice information visiting a web page but some web pages no longer current.
Steve Kniffen
Here's another link for rings made from colored pencils: http://www.youtube.com/watch?v=xPAK_jR-RKI
I tried his technique, using CA glue, and when I tried to turn the rings, things came apart. The glue pulled the paint off the pencils. I'm going to try again using epoxy. First, though, I have to find some colored pencils that are hexagon shaped. All I'm finding right now are round pencils. Hex shaped pencils give flat surfaces to glue.
Steve
