Celtic knot in 10 minutes *LINK*
OK it's pretty good. I like his technique although it can get tricky getting the wood to the bottom of the cut and if your insert pieces aren't the exact thickness you can get glue gaps. However it works. I still use the cut completely apart method and use titebond 11 and let is sit overnight. slower but very good glue joints.
I do have a problem with his free hand bandsaw method. I realize those are pretty thin pieces and cut easily but all it takes is a millisecond for the saw to grab and you could get hurt. The much safer method would be to put one end down on the saw table so you have some support. then hold the other end far away from the blade. The wood being supported on the table would reduce the likely hood of a catch and with your hands well out of the way would reduce the chance of damage.
The problem with a bandsaw is it can seem safe. Kind of like "it seemed like a good idea at the time".
I frequently use the Sam Maloof way of free hand carving on the bandsaw. It looks dangerous and it can be. If you follow the rules I put above which is always keep the wood supported on the table at or near the blade, and always always keep your hands well away from blade, you should be safe.
https://www.youtube.com/watch?v=UwK6n3iSyh0
