Need assistance with rosettes
AZ in Colorado Springs
I'm trying to make some rosettes out of maple. The wood is 1-1/4" thick, & 5" square. It's plain stock, not figured. I want to cut several concentric rings about 1/4" deep, starting 7/16" from the center, then every 7/16", for a total of four rings.
(One can buy rosettes, but they're about 3" square. Alternatively, one can get a bit for a drill press, but they seem to top out about the same diameter, maybe at 2-7/8". I want to make something a bit wider since this trim will be placed along the edge of a loft, about 11' high. I'm making fluted trim to go along with the rosettes.)
I have a piece of plywood mounted to a face plate, and screw through the back of the plywood, into the back of the work piece. The work piece is securely mounted.
I've tried using a narrow bowl gouge and a narrow spindle gouge to simply cut the circles, but I keep getting catches, which tears up the work piece. Suggestions?
My lathe is a Rikon 70-050VS, midi lathe.
Thanks
Andy
