This is how to sharpen lathe tools :-) *LINK*
https://www.youtube.com/watch?v=zleVA9yxdm8
Re: This is how to sharpen lathe tools :-) *LINK*
I've seen the unglazed bottom of a plate used
#3Re: This is how to sharpen lathe tools :-)
Phillip Medghalchi
John, how about the bowl gouge.
#4I was betting he started with a sharp knife.
Keith Newton
I had some serious doubts that he started with a blade that you could see the shine from being dull then ended up with a shaving blade that quickly.
I thought he started with a keen edge, then he might have burnished it a little at best. Or he might have laid it down a little more, then rode on the heel of the secondary bevel, and done nothing for the actual cutting angle. But then, I pulled out my pocket knife, which had a little shine, then went out to my truck, and darned if it didn't work.
Good to know, but I don't ever expect to use this tip again. I always have a file and diamond hone under the passenger seat or in my pack. When I do my skinning show, if I wanted to wow everybody, I'd rather pick up a couple of cobbles out of the gravel road, and show how to flake off a few sharp edges using the Hertzian cone angles to strike them just right,,,,,,,,,,,, uh, if I knew how to do that. he he
#5Re: This is how to sharpen lathe tools :-)
robo hippy
Well, I never was a chef, but an old trick from them was to hone on a wine bottle.
robo hippy
#6Re: This is how to sharpen lathe tools :-)
steve worcester
wine bottle, window glass, same difference. If it in't woodturner sharp to start with, won't matter. The window is about 12000+ grit (a SWAG), any cuts in the metal and it won't fix them.
