ADVERTISE HERE - FREE TRIAL
new mirror
new mirror
new mirror
This mirror was fun although a heck of a lot of hand sanding. My Friend Jim Bentley is 89 and pretty good turner and retired architect so he has a good eye for design. He was going to make some mirrors for his granddaughters for Christmas and purchses the wood and glass. Now he's having eye problems and decided he might not be able to make them so he asked if I would.
Well I got the wood home and realized it's 1/2" thick. I usually make mine out of 3/4" stock. He also bought 6" glass. Way to big for my normal design. I started thinking about how to do them and ran this design by him. He liked it. Of course it meant almost completely carving the thing and a lot of hand sanding.
Of interest to the discussion about negative rake scrapers. I turned the backside of these. That meant turning that extension piece where the handle went. It is extremely thin and flexible and I was having a lot of trouble turning it with the gouge. I pulled out my negative rake round nose scraper and did it very successfully although very scary. Since I could not even see the area where I was turning while it was spinning I had to be very very careful. I am pretty sure a regular scraper would have grabbed the thin wood with disastrous results.
The handle is epoxied into place and then pins put in from the back at different angles so the handle won't come off even if the glue fails.
Finish is 3 coats of Minwax wipe on Poly that was buffed with tripoli and carnauba wax. I didn't dare touch it with the white diamond, not with that texture and the open pores of the Padauk wood.
Of course I have to make 2 of these. The other one is done and the first coat of finish applied. Takes about 3 hours or more to carve and sand these pieces. My fingers were quite tired.
Re: new mirror
Re: new mirror
Don McLeod
John your mirrors are always a work of art and this one is no exception. Nicely turned, uniquely carved and finely finished.
Re: new mirror
Keith Tompkins
Re: new mirror
Keith Tompkins
Good job, John!
Re: new mirror
Re: new mirror
Phillip Medghalchi
John, very well done. it has more of a contemporary look to it. the ideas of the dowels came out nicely too. not only it adds strength it also adds design element to it. Very nice.
Re: new mirror
Wow John!!!
Don Orr
When you get back on the lathe you sure don't miss a beat-even kick it up a few notches. All these new pieces are exceptional. But we tend to expect that from you. The mirrors are particularly wonderful. Great work as always and very glad to see you back in action!
Re: new mirror
Re: new mirror
bowlman
good job my friend, good job ... or as Tony the Tiger says ..."GRRRRRREAAATTTT!!!!!"
Re: new mirror
Now your showing your age Dick :-)
Re: new mirror
Second mirror done
These are for my friends daughters. The first one took about 5 hours to do. I got the second one done in about 4.
