200+ woodworking book reviews
Spindle turning question
Keith Newton
I don't really consider myself much of a spindle turner, but do occasionally need to do some replacement parts for neighbors.
I'm thinking about turning some 5.25" square X 8' long Western Red Cedar porch post, and have some concern about using a tapered live center on the tailstock of this soft easily split wood, and wondering if I should order or borrow a cup center, or am I over thinking this?
While typing this, it just dawned on me that I could gang screw on a plywood endplate.
Do any of you have any thoughts on this?
Re: Spindle turning question
I doubt a cone center would split a piece 5 1/2" in diameter. or like you say, just screw or hot glue a waste block of plywood on the tailstock end and center drill it.
Ken Vaughan
Ken Vaughan
To limit the depth of penetration of a cone shaped center, I put a washer over the tip. Pick the size of washer to allow the amount of cone to sink into the wood appropriate for the material being used. Some cedars are split prone.
A 1/4 inch or 3/8 inch washer hole fits most situations on a 60 degree live center
Sergio
Excellent idea!!
Janice Manuel
I've had to turn big posts like that many times...what I did to keep them in the lathe...because the softer wood simply isn't strong enough to hold the cone center without wearing the wood out...I made a metal piece with a countersunk hole in the center and a couple screw holes on either end. Mount that on the spindle, let the center ride in the hole and all is well...The screws are well out of your turning area on a big square so there is no danger of turning into them. Worked for me, and I've done big spindles up to about 10" diam...
Exactly what I thought
Thanks Janice
Keith Newton
For confirming what I expected. I've also talked to a couple of other pro turners who have indicated that the wood just can't stand up to the shock loading that I would expect something this large would deliver.
I have some scraps of aluminum plate around here that I think will work nicely for this. The live-center that I'll use has about 1/2" of straight 3/4" diameter shaft before the tapered cone starts, so I think I'll drill a center hole that large through it, then burry the taper in the end grain.
For the powered end, I have a 12" faceplate 1.5" thick that I will screw a thick plywood disk onto, with a square socket hole in the middle that will receive the end of the post, then I'll add a few long screws to draw it in and retain it.
What could possibly go wrong??????? Hey Bubba, Hold my beer, and watch this here! He he
Re: Thanks Janice
Keith I think your biggest problem will be chatter when turning the middle section. maybe not, who knows. I turned a 5 1/2' piece that size and it wasn't a problem but your adding another 2 1/2' so who knows. Good luck on it. I think your idea of drilling a larger hole to keep the point out will be a good choice.
