new ornaments
new ornaments
new ornaments
Well I am finally turning again. Well mostly carving but you'll see that project in a few days. I turned these ornaments. The celtic knot blank was a gift from Skip Wilbur in Memphis. I stayed with him this last weekend and had a ball. It's been probably 10 years since I did a celtic knot. I put it in a mirror handle of course. :)
I enjoyed turning this one but almost lost it. It was getting thin and then blew out in 3 places on the celtic knot. apparently there was end grain areas there. One I was able to just tap back in place and thin CA. The other two I had to fill. I created some sawdust from the maple stock. Then I took a paint can opener and covered the bent tip with masking tape. I put that inside and pushed the tape against the small hole. Put medium CA in the hole and then pushed sawdust into it. sprayed it with Accelorator and then put some more sawdust on tip and put thin ca on that. Worked perfectly. One hole is invisible the other one is not noticeable by most people but observant turners may find it.
Maple and blackwood on the celtic knot. Abrosia maple and cocobolo on the other one.
Re: new ornaments
Re: new ornaments
Vincent Welch
Good to see you back in the shop John! Nice work!
Re: new ornaments
Re: new ornaments
Those are beautiful. If I had any criticism I would say the drops or icicles appear a bit voluptuous.
Re: new ornaments
ebd
Re: new ornaments
ebd
Sweet.
Re: new ornaments
Re: new ornaments
Donna Banfield
With all due respect to Barry, :-) I think those icicles are some of the best finials ever turned. Great to see you back in the shop again, John. And even better to see that you haven't missed a beat in your skills.
