Question about wall thickness (pic)
Mike Potts
I turned this bowl this afternoon, normally I use calibers to check my wall thickness. but since I added beading and changed the normal bowl shape I couldn't get the calibers to work. What do you guys use in this situation ?
Thanks in advance
Mike
Re: Question about wall thickness (pic)
There are many calipers that will with reach into that shape.
You could also "adapt' some you may already have. Fiddly, but you could cut a piece of two of dowel say and inch long and hold one on the outside and measure with straight jawed calipers.
I have a home made set that are like a big pair scissors with the blades that close into a circle. The "trick" is the handles are exactly the same length as the "blades". When they are closed, the inner surface of the handles are flush. You can put them onto a bowl, or hollow form and feel the thickness and variation without looking at them. By looking at the end of the handles you can see how thick the walls are. I will post a picture if you care.
Other than that, I use my fingers, but the little devils will lie to me.
Lyle Jamieson
Lyle Jamieson
Set the caliper to a thick measurement say 1/2 inch or 3/4 inch. Measure the air gap at different places in the bowl to see how much wood is left.
robo hippy
Well, for sure, where the beading is, you need the walls, including the bead to be a bit thicker. With that outside design, I would have a more traditional inside, and not follow the outside design. It just doesn't 'feel' right when you move your hands on it. So, I use the D shaped bent wire, where you leave a 1/4 inch gap or so that floats over the thicker parts. Most important is not to go too deep.
robo hippy
What Lyle and Reed said. Make your own. I use a C shaped piece of wire and leave a gap that is 1". Then place the wire touching the inside or outside and measure the gap. If it's 3/4" then the wall thickness is 1/4".
I also agree with Reed in that I would make the inside a more traditional shape unless the wood is still green. Then it might be too thick and could crack. The wall thickness doesn't always have to be exactly the same through out for every bowl. It's your bowl so make it look good and function good to your taste. Later on you will probably learn to change your design but the thickness gauge will still work.
That being said I have one of the Keith thomkins thickness gauges that works extremely well and fast and easy to use.
Phillip Medghalchi
John, I wonder what happened to Keith, I hope he is on vacation or something. And, all is well with him.
I like to wither get his plan to make one or if he has for sale I like to look into it. I have the large Sorbey thickness gauge, but I wasn't thinking of buying the smaller one for smaller bowls r boxes, and it is not that cheap either.
Packard sells them *LINK*
Keith still pops up here occasionally. You can get the Gauge T from Packard who is a WC sponsor
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=meas-wallthic
Re: Packard sells them
Phillip Medghalchi
John thank you for the link. I wonder in the video it mentions that the gauge can be bought directly form Keith, then it cuts off.
Mike Potts
John, thanks for the link, it looks like a must have tool, I ordered it this morning.
Mike
don stephan
A large figure eight caliper works well for me. Can't remember where I got it. Usual suspects are Craft USA, Packard, and Lee Valley.
Keith Tompkins
Keith Tompkins
HI Phillip, Thanks for your concern.....I am alive and well, thank you! My schedule is a little overbooked, so sometimes I don't post as often as I'd like. I'm prepping for an upcoming demo in Arizona, and working on pieces for an exhibit. I just shipped out an new shipment of gauges to one of the turning distributors.( Just to clarify, the gauge was originally cast from urethane,as the Packard ad states, but is now injection molded from glass-filled polycarbonate.) :D
Keith Tompkins
Re: Thanks John!
Mike Potts
Just wanted to thank all those who gave their insight. I am going to try Keith's gauge,and the next bowl I turn with the non- traditional outside I will try the curved traditional inside.
Thanks again
Mike
