Jet 1236 spindle pulley
Don A. DAvis
It seems these pulleys are no longer available (at least that's what I'm told). I need to replace. Any ideas? Alternate parts? Will pulley's from other machines fit? Thanks for any help!
Don A. DAvis
Re: Jet 1236 spindle pulley
I went to several sites and they still sell the 1236. Where did you check on parts? Is yours an older model.
Don A. DAvis
John...I went to "Jet Parts Store" and "Ereplacement Parts" Both say no longer available. Lathe is about 7 years old.
Try Grizzly
Dick Coers
theirs is probably made in the same factory. I don't know that as a fact, but just makes sense to me.
If you can try to call them and talk to someone. They may know if the current parts would fit an older lathe. I've always had good luck talking directly to the Jet/Powermatic people.
I hate dealing with electronic stores. I just ordered a part using the exact part number for a jointer that i have. The part was incorrect. I will call and talk to a real person tomorrow and hopefully get that straightened out.
Matt Overton
what is the problem with the pulley? on my old 1236, I was able to fix the pulley after it stopped working from too much abuse trying to make it go slower. The snap ring is what broke on mine. It was just a $1.50 snap ring and two of us wrestling it in for about two hours.
Don A. DAvis
The problem is the half pulley that slides (Reeves drive) on the spindle has become worn and "sloppy." The three Jet parts suppliers I checked on the Web all said "no longer available." Today I smartened-up and called tech support at Jet seeking an alternative. It is true that part is no longer available. HOWEVER, they now sell both halves as a single unit with a new part number (known only to them). So, the problem is hopefully solved.
