I read some where , could have been Play Boy, that to keep the film from forming on the service of finish, like salad bowl finish, you could put a piece of food wrap on top of the finish. This was to keep the air from forming a film on top of the finish.
I have a can of General Salad bowl finish that I am storing upside down and it seems to be working. I only use occasionally and so far, so good. My theory is that the liquid seal prevents air exchange via the lid seal as the pressure changes in the can due to temperature cycling in the workshop.
Storing upside down would sort of work. But the bottom (as you open the can) would be more solid and oxidized.
Putting plastic wrap over it would only work if you could remove all the oxegen (actually the air) from the can before you close it.
Ideal it to put a layer of inert gas heavier than the atmosphere over it before putting the plastic wrap over it and closing.
Bloxegen does that, it is inert (Argon if I recall) so it does the job.But it ain't cheap. There is a product by PolyTek that seems to work for me, but I don't know what is in it, or have extensive research with it. They don't say specifically what it is, other than it is heavier than air. Based sheerly on can weight, it will also a lot longer than Bloxegen.
The Polytek product might be Poly Purge (Tetrafluoroethane). It's intended to displace moist air to help extend the life of polyurethane liquids. Some wine shops carry a product much like Bloxygen (argon + ?) that seems to work well for me at a lower price.
Dick. I have an ongoing experiment. I bought some of those refillable tubes used in camping. I'm away from home or I would tell you exactly what they are. I decanted some finish into one and squeezed the air out of it. It's been sitting there for many many months and is still good. I wish I had written down the date. Maybe we can do a search and find when we had that discussion here.
I started storing my finishes upside down several years ago and it works much better than CO2 or Argon. I haven't seen a film develop on any surface. I'm guessing the finish uses up the available oxygen pretty quickly and then there is effectively an inert air layer between the bottom of the can and the finish. You might have noticed this effect if you store finish in a flexible container, it collapses over time.
Tried that. Didn't work very well. And really messy each time you want to use the finish. Best solution I have found is to store the finish in glass bottles with a narrow neck, saved from the kitchen. Glass works better than plastic. When I open a new can of finish, I pour it into a variety of bottles. Fill each bottle right up, and it keeps for months.
Several members in our Minnesota club have already tried the Stop Loss Bag idea that Neil Robinette has suggested above and believe it to be a very effective, long term solution. You can see and feel that all of the air has been removed from your stored & easily identified & date marked finish, from each and every usage.
Certainly worth your time to check it out at:www.stoplossbags.com
