Arbortec contour sander *LINK*
JUst watched that add. I'll have to try one when it gets to the states. Not sure I relish holding my Angle grinder which is fairly heavy but if it sands as good as the add shows you won't have to hold it long. I would prefer Hook and loop to the stick on abrasives but that could be changed. Anyone have one yet?
http://www.arbortechusa.com/view/woodworking/contour-random-sander/
Re: Arbortec contour sander *LINK*
Don in Central Illinois
Sounds great. Anything to help me spend less time sanding.
Joe Bradshaw
Joe Bradshaw
I just got mine. It works really great. HF has a lighter angle grinder that my girlfriend uses for hers. I have a lighter Ryobi that I use. I plan to put hook and loop pads on mine as soon as I wear out the sticky pads.
Joe, where did you purchase it? And approximate cosr?
robo hippy
I am wondering what a "random" sander is. Like a 'random orbit' sander? I did look at the angle grinders, but most of them are very high speed.
robo hippy
Treeline $85 and shipping
John, You might like what I have better, *LINK*
Keith Newton
I've had a Sioux mini random orbit sander for many years, with 3" hook and loop disk, but about a year ago, I bought another small Chicago Pneumatic RO sander which also came with a smaller 1.5" hook and loop disk. I really like having both of these, and since the disk is closer to my knuckle than the one in your link, I'm sure I have more control, not to mention that it is infinitely variable speed depending on how far I pull the trigger.
I've been doing some carving some bird skulls lately in fiddleback maple, for lids of some cremation vessels that are fairly intricate in detail. As you might imagine, chisels would make a mess, since it would be impossible to cut with the grain, so most of it is done with grinders / sanders.
I have a set of punches from my Mom's old fabric button press from our store back 50 years ago, that I use to punch my own disk in the size range from 3/4" to 2" out of the 6" round disk for my PC sander.
I stick these on various size disk which I've made from 1/8" shank grinding wheels for other tools like Dremel. I use spray contact to totally saturate pads punched out of an old Porlartec sweater. This of course sets up as a soft fiber reinforced rubber which the adhesive disk really adheres well to. In fact I can't peel them off cold, so when they are worn, I run them fast while holding them against a waste block to generate enough heat to activate the glue.
In a little right angle Harbor Freight air grinder, less than $15, you are good to go.
http://www.amazon.com/Chicago-Pneumatic-CPT7200S-Random-Orbital/dp/B000NE0T68
I purchased a Grex and I'm much better
at sanding with my drill. The Grex works but it seems to be very slow at stock removal and of course eats up lots of air. I haven't used it to sand carvings yet, just bowls and it's very slow on the bowls.
Leo Cuellar
Re: I purchased a Grex and I'm much better
Leo Cuellar
Interesting product, John. If you threaded a 10 MM bolt into the adapter & cut the head off the bolt, you could probably use it in your drill. It might not run fast enough for the RO feature to work well.
I have had good luck using a plug in router speed controller to slow down my angle grinder for more delicate jobs.
They sent me a PM thinking it would help me
mike foster
I was flattered that they found my website and took the time to PM me. I am not certain that it would help me in my work. For one thing, I don't like to sand at the speed of an angle grinder and find holding an angle grinder tiring for some of my weird turnings. It might fit on my Foredom. I have a hand piece for it that will accept 2" sanding discs and Arbortechs mini carver (can't remember the name) that was intended for use on an angle grinder.
I think I'll wait till I hear what other have to say about it.
Re: They sent me a PM thinking it would help me
steve worcester
I would love this, but I want to know how they get random action out of a machine that doesn't (it only turn round)
I have a Grex and several other randoms, and they bog down. An angle grinder wouldn't. I can make a whole family of sanding disks if I can figure out how they do this.
Hal Taylor
I have not used it yet, but had the idea of adapting it to a drill. Does not work that way. It needs the speed of an angle grinder.
Phillip Medghalchi
Steve, it might bet that the random orbiting feature is in the head itself rather than the arbor or the shaft? To me idea of holding a grinder to do those fine little crevices for a long time doesn't ergonomically sound right ( from my back ground in health care). Not for the long time we hold it in our hands to sand. then yo would develop long list of hand problems. Grinders are held differently in yor hand and not for a long time jobs. Unless the guy who came up with the idea can come up with some explanation. Remember the computer key board, when the guy came up with it, he was a computer designer not a health care provider and didn't know what it would do to our hands, that's why you go around nowadays and see people in those black splints around their wrists because they came down with carpal tunnel syndrome. I think that's the last thing we need with our hands if we don't already have it. the idea is good and yes it will help, but if it works with drills so you do not strain your hands. Even the ones that Captain Eddie has it on his video. is a nice thing then you let the rotation of the bowl rotate the sanding disk also.
I use an angle grinder a lot for shaping wood and metal and it surprises me sometimes how fine the control
Is with 2 hands. However both of mine are quie noisy and relatively heavy and I'm not sur I would want to spend hours sanding with one. As everyone who does this kind of work knows the first grit is the slowest and most important so if it would speed that up it might be worth it
