Bandsaws and bowl blank prep
Re: Bandsaws and bowl blank prep
Excellent Reed
Steve Worcester.
Really well done. My only comments would be to talk about the brake on the one saw and the size of the blade in reference to the blank diameter you're going to cut.
Of course, maybe I liked it because it is exactly the way I would do it. But I have the big brother to your saw, the 24x24.
Excellent.
Bill Boehme
Very nice video. Except for some small details, it is very similar to my Mini Max MM16 that I bought back in 2004. Back then, they were in Austin so I just drove down and picked it up. I noticed that the price of a new one has just about doubled in the last ten years.
Vincent Welch
Nicely Done Reed!
robo hippy
Bill,
I think that was the same time I got my Laguna. I have a friend who has the mini max, and from all reports, it is an excellent machine. I really like the ceramic guides. I cut a vent slot in the bottom of the door and put an angled vent in it to improve dust collection. It works great. I will get a short clip of it up eventually. Really, how hard is it to figure out that you need to put the vent where the dust and shavings pile up?
robo hippy
Ken Cutler
Nicely done! What is the blade specs on the smaller saw that you used to cut out the bowl?
robo hippy
I use the Lennox Bimetal Diemaster blades. Best ones out there. The small saw has a 1/2 inch by 3 tpi blade, and it is the thicker one, but can't remember the specs. The thinner ones would just wobble too much, and bend and flex while I was using them, even if they were sharp.
robo hippy
Phillip Medghalchi
Reed very well done, the explanation and precautions. sometimes your voice doesn't come loud enough int the video, but then again it is very hard to have the machines run and your voice be heard at the same time. Thanks again for sharing this.
