Re: Which Thread Chaser
mo'wood
There are two tricks that I have learned make a big difference with hand-chased threads, and they will allow you to cut consistently clean threads on domestic woods such as hard maple and walnut-as long as the annual rings are fairly dense. (tighter annual rings will work better than more open grain).
1. Most new chasers are ground with too much bevel relief that rips out the cross grain. Try grinding / honing a small negative rake angle on the top of the chaser teeth- it slows down the aggressive cut of a typical chaser, and prevent the grain from ripping out as much. An included angle that is around 90 degrees seems to work just fine. Be sure to set your tool rest so that you are cutting exactly on center line- the handle of the chaser should be nearly horizontal in use.
2. Prior to chasing both interior and external threads, try soaking the surface of the wood with a mixture of about 90% Dawn dish-washing liquid cut with 10% denatured alcohol. Let it soak in for a few minutes, and using a sharp chaser carefully strike the first thread. The soap acts as a lubricant in a similar way to how dense resinous woods cut, and produces more of a ‘slurry’ rather than chips or dust, but the resulting threads are crisp. The problem with chasing threads in kiln dried wood is that it like trying to cut a cracker- the grain breaks and chips. The soap solution makes the wood less brittle (and also gets your dishes sparkling clean).
I agree that 16tpi is a good general size down to about 1 ½” diameter, and the 20tpi is easier learn how to use. I prefer the nice double-end chasers that Mark St. Leger sells.
I have a bunch of other tips that I have collected for when I teach thread chasing- drop me an e-mail and I will send the handout to you.
-Michael
