Bent Lamp Auger
Blondterror
Any suggestions on how to salvage this lamp auger.. I stopped using it 2 yrs ago when I bent it and now need to make some more tall lamps
Bent Lamp Auger
Blondterror
Heat and patience
Dick Coers
Probably heat, but since it not break, it may not be hardened. I would still heat it, then start the hammering. Strike and roll to check straightness. Keep that up till it's straight enough. Likely not to get perfectly straight, but I imagine you're spinning the blank on the lathe. You could work in the corner of angle iron, but you have to over bend it to get it straight.
No heat needed
I would straighten like I straighten arrows. I have also used this method to straighten blow pipes for glass blowing. Basically you put some V blocks under both ends usually centered on the bent area. Rotate it so the high point is up and then push down on that area. Takes patience but I e done many arrows so they were perfectly straight
You use steel arrows? LOL
Aluminum. Back in the days before carbon fibre
Re: Bent Lamp Auger
Leo Cuellar
I would try without heat as well. A hard & heavy plastic or wooden mallet to save wear & tear on the flutes. Copper mallets work well also, if you have one. Brass is sometimes too hard for delicate items.
Re: Bent Lamp Auger
Just rig up a lever. Clamp a board to your workbench with spacers underneath Then put a board under that to push down on the drill. This allows you to flex it down a known amount. With the drill in the v blocks you can easily flex it beyond horizontal which you will have to do to get it perfectly straight.
Re: Bent Lamp Auger *LINK*
This should show you how a straightener works
http://www.amazon.com/gp/aw/d/B000LVK2C4?pc_redir=1411906507&robot_redir=1
