Re: Apple Natural edge Calabash bowl
Rum
Very nice looking piece of wood, glad you managed to save it. I have a few pieces that I'm pretty sure were almost as much CA as wood once I was done; I kept those because I'm pretty sure the CA will eventually fail but they're a nice reminder of where I've been. I suspect that the knot in the side wasn't helping you here either.
disclaimer: I haven't turned a shape I've been 100% happy with yet and my set of attempts is still relatively small in the grand scheme so take this for what its worth based on that
Also this is all subjective and just my eye so I'm sure others would/should disagree or have better suggestions
I really like the bottom and center part of the form, it has really nice continuous curve and draws the eye around the wood nicely. Its also a great for for a piece with that much grain since it really shows it off nicely!
I might have tried to round off the foot into more of a bead, but it looks pretty nice as is (and there's always the possibility of there being no foot left when attempting that).
I think it ends up a smidge to straight near the top side, but not egregiously so. The main area where I'd have probably tried to mix it up (and odds are failed and blown apart the interesting bits so I can understand why you were more conservative
) is around the rim and the transition from the side to the rim. If that transition had been eased I think it would have alleviated some of the perception of flatness on the upper side of the form as well. I like beaded rims on some bowls but I think they distract some on natural edge pieces unless you're really really good at them.
I've taken the liberty of lightly photoshopping one pic to show what I was thinking of on the transition (only did the sides because my photoshop skills are.. stale is an understatement). I spent a bit more time on the right side than the left so if it looks uneven.. its because it is
