Number 2 vessel off the camera system
Dick Coers
Finished a spherical box elder vessel today. 4 3/4" diameter, weighs 4 ounces, I left a little extra in the bottom. Learned a new lesson about box elder today. It was difficult establishing the spherical outside shape, to be able to hollow thin, and leave enough material on the stub held off the chuck. I found out I left too much material near the center of the form. It started to chatter as I finished the cuts on the inside, then moved nearer to the bottom. When I took it off the lathe, I found that the wood had fractured around where the outside shape met the stub. I had plenty of wall thickness, just not enough strength. I filled it with titebond, then sanded it smooth. Too nice to pitch, I'll see how that crack works out. Another couple of chatters, and it would have completely blown out the bottom.
