skewchigouge?????
skewchigouge?????
skewchigouge?????
Gordon P Patnude
I just saw this term on a website >.
Does anyone know exactly what a "skewchigouge" is, what it looks like, and where the he** did it get the name??
Re: skewchigouge?????
Alan Zenreich
Alan Zenreich
Crown markets one designed by Alan Beecham. Google is your friend.
http://youtu.be/j1XnGeDSvhs
Gordon P Patnude
thanks, Alan. Just looked at it --- unusual, but interesting!!
James Heaston
I was hoping you were going to tell us it's the best thing since the vacuum chuck. :\
Mike Stafford
Mike Stafford
It is easy to make one from HSS round bar stock. I have a couple in my arsenal of unused tools.
The tool is essentially a fluteless gouge/scraper. It works but not as well as a gouge or as a scraper.
Here's some pictures of one I made.
Lyle Jamieson
Lyle Jamieson
If my memory serves me right the original Skewchigouge/skewgigouge was named and used by Melvyn Firmager from England. He holds classes and teaches people to turn with a very different set of tools ground differently then anybody else in the turning world. They work well, but most are very aggressive and it take a bit of learning curve to master his techniques.
robo hippy
It has been around for a while, but hasn't really caught on. I remember Allan Batty using some thing similar in a workshop I took with him and Stuart. He used it like a spindle/detail gouge. I love it for getting into tight spaces, like a finish cut on the dove tail part of my recess. I have a fluteless gouge clip up on You Tube if you want to see it in action. It works nice for beads and coves as well, and I think it might have an advantage over a gouge because there is more metal. I have used it upside down as well for getting into areas that I can't reach with a gouge. I do use the fluteless gouge from Doug Thompson for this variation.
robo hippy
Dick Coers
It can also be used as a left and right shear scraper, although the cutting surface is not as long as John Jordan's style shear scraper.
Gordon P Patnude
Thanks for all the input, guys. I'm hardly in a position to comment on much of anything as I have only been turning regularly for a little over a year, and almost everything is new to me!
Keith Tompkins
Keith Tompkins
Gordon, the skewchigouge is flat on top, the lower section is rounded. The instructions say to hone the top, but don't grind the polished bevel. (I have my doubts about how long that bevel will last before it needs to be ground.) It is essentially a gouge without a flute, something I've been experimenting with for years; I have several examples that I consider a valuable part of my tool arsenal. In theory, the tool will cut much like a skew chisel if presented correctly, and since it has no flute, it is less likely to catch than a regular gouge if the gouge is not used correctly. If the cutting edge of a skew is unsupported by the tool rest, a spiral catch will result, if the side of the flute on a gouge touches the wood in the wrong orientation, the gouge will catch, and roll into the cut with, well, not good results. With practice, the skewchigouge is a useful tool, but still more worthwhile to master the other two. My tools are similar to Mike Stafford's, but they have a longer side grind, and I've ground the top bevel so there's only 1/8" of bevel remaining. I feel that lowers the fulcrum point, and the tool is far less likely to roll over by accident. I use mine for detailing fine finials, and for end-grain hollowing...no flute to cause excess vibration.
Nick Stagg
Lyle, I think the credit for the Skewchigouge goes to Alan Beecham
Dwight Rutherford
Kieth, Robo,
Are the skewchigouge and the Fluteless gouge one in the same?
robo hippy
The Thompson fluteless gouge is made from half round stock and is used mostly as a bottom feeder type gouge with a 60 to 70 degree bevel. The Skewchigouge is made from round bar stock. You grind the bevel, and some times you have to grind the top to remove more of it. It is usually sharpened to a 35 to 45 degree angle.
robo hippy
Lyle Jamieson
Lyle Jamieson
Again if my memory serves me correctly, and who knows how well that is working. Has anybody out there worked with Melvyn?? We may be talking about two different things. The name and the tool may have differences. It could be two different things called skewchigouge. I thought the Firmager gouge had a flute. I looked at his web site and there are no photos of his grinds...no help.
Craig Daymon
I like my skewchigouge. I would not buy one, but making one is very easy. I find it very useful for making delicate cuts, especially at modestly extended reaches. I've used it to undercut an overhanging bowl rim and create a sharp transition that would be difficult with a conventional gouge.
Also works just fine for spindle work or shear scraping a very delicate and specific area because the more pencil-like shape is easier to use that a broad scraper.
The solid shaft is very rigid and not prone to vibration.
Definitely not ideal for heavy cuts, though it can take a heavy cut on a spindle and I would not use it to hollow a bowl. Works well as a straight tool for small hollowforms.
Thompson sells tool blanks that would work well for making one, or just buy a HSS drill blank from Enco or McMaster-Carr.
Thompson detail gouge
I like my detail gouge for anything where I have to reach over the tool rest very far. I do a fair amount of inside out turning as well as some spindle work that often require some serious overhang and my 1/2 Thompson detail gouge is fantastic. The 3/8 detail gouge with a 35 degree grind will reach into just about a y tight spot
Keith Tompkins
Keith Tompkins
YOu know what.....I'm thinking of the spindlemaster, not the skewchigouge. The spindlemaster is completely flat on top. My bad... >(
Nick Stagg
Lyle, If you Google Alan Beecham Skewchigouge you'll see the original tool; made by Crown Tools. I bought one 10 years ago.
Melvyn had some double pronged hollowing tools and a parting tool that he used as a shear scraper; it's a deep tool and he used the "U" shaped part above the tip. he had some more homemade tools but I can't describe them.
nick
Lyle Jamieson
Lyle Jamieson
Yes, Iv seen Melvyn demo with them and I could not describe them. Very complex. I don't remember the odd names he had for each concoction, not traditional by any stretch of the imagination.
