First impressions of the optical system are really good. I felt really confident just inside the rim and the base, knowing exactly where the entire cutter was. A nice benefit was when parting off. This thing makes a wonderful depth gage. Mark the cutter on the acetate, send it to the bottom of the vessel, bring in a pencil and mark the cutter location on the vessel. For the money I have in this system, just using it for a depth gage would be worth it. But for the comfort factor so far, it might just become my go to guide. Box elder vessel, 4 1/2 diameter, 4 3/4" tall. Weighs 2.8 ounces. Right at 3/32 wall. I could have gone thinner, but this is dry wood and dry box elder sure isn't known for it's strength.
Dick, that's a great job. I enjoy using mine. It does a very exacting job. My camera/TV magnifies the image making the cutting even more precise. I've ordered the borescope from ebay you used and want to try it. It looks simpler, since you're only dealing with one power supply to the laptop, and even that's optional.
You just bring the tool into the opening, then watch the screen. It is more natural than I thought, but you are watching the entire form spinning. It's a bit like watching the top of the form while you define the shape on the outside. Your eyes aren't on the tool then either. Then you bring up the line you have drawn on the acetate, onto the outside of the form. It's like bringing two lines together, very accurate! It's even easy to anticipate form changes as you skim along for final cleanup. You still get an advantage of knowing the entire cutter shape with the camera in this final cleanup, while you not have been able to with a laser. I'll try it soon on a larger form, using the round carbide cutter. I think it will be even better in that application.
There were a couple of other images in the post linked here showing camera imagine quality, and camera mounting. Not much to show. One USB endoscope camera in a Jamieson laser holder, one old lap top computer, a piece of acetate taped to the lap top screen, and a fine tip dry erase marker. That's it. Really cheap if you have a lap top or can put your desk top near the lathe. My camera has a 15' cord on it. The use was discussed in that previous post I linked to. PM me if you need a specific part number on the camera, but there are tons of them on ebay. I had no idea they existed until I started this little experiment. I don't want to list specific parts across the internet since JT Tools and Trent Bosch are marketing systems to do this. JT has a high tech solution with some specific software written to control some variables, along with an Android device sold with their system. I can't see exactly what Bosch is marketing. I'm pretty sure no software, just hardware for camera mounting, wires, and a monitor.
Thanks Dick! - I guess I totally missed that part of the previous posts...
It seems that I now have to give this a try... just for the tinkering factor alone, this seems like a reason to resurrect that old laptop under my desk!
