Trend Air Pro
Trend Air Pro
Trend Air Pro
Phillip Medghalchi
Hi, folks,
I bought my first Trend face shield when I went to SWAT this year and last Sat. I went to wear it and lo and behold, I go to wear it and the head band was broken. when I talked to the Vice president at the SWAT, I mentioned the concern about the battery and that it doesn't hold up that good and it needs a separate charger, and if they were aware of the problem, which he responded that now they use a better battery and it should hold up longer, then he mentioned that the only problem they had with the shield was that if you had the gray color head band then it would brake and had a new one made in the color of black. however, mine is black and was never worn until Sat. and it was broken.
I called them adn they are sending me a new replacement head band. My qsn. is that was there any other problems I should be aware of id you have just bought the shield recently and are you satisfied with it?
Re: Trend Air Pro
Alan Zenreich
Re: Trend Air Pro
Alan Zenreich
When I had my Trend, they replaced the headband twice... No questions asked, overnight or second day delivery. Great customer service, for a very good product.
Re: Trend Air Pro
Mike Peace
Smart Charger for Trend Air Pro
Mike Peace
Battery problems for the Trend Pro are primarily from overcharging with the dumb charger that comes with the unit. Here is a video I did on a smart charger fix
https://www.youtube.com/watch?v=ZV-yMPfvRsY
Re: Trend Air Pro
Re: Trend Air Pro
Roger Chandler
I have had my Airshield Pro for about 2 years........no problems, except one of my own making. I got too impatient for CA glue to dry, and ended up splattering the faceshield pretty good. Got a replacement for it.
I am not sure this is a problem, but after two years of pretty heavy service, the elastic band on the outer rim of the face seal stretched out and would not seal around my face, so I did replace that a couple of months ago........the new one seems to fit a bit tighter than the original one, which I like and gives me a better seal than the original.
My only complaint is the pricey nature of the filters.........they seem to need to be replaced too often to suit me, but one can back blow the filters out a few times and add life to them, but be careful not to use too much air pressure....you don't want to blow a hole in the filter material, and you should take them out of the helmet to keep from a chance of breaking the fan unit with the motor on it.
I have gotten good service from my unit. I bought extra tear offs for the face shield and occasionally replace and the battery cradle for charging one of my 3 batteries outside the unit when I use a fresh one in the helmet.
Re: Trend Air Pro
Re: Trend Air Pro
Phillip Medghalchi
Gentlemen, thanks for your reply. I have to look into making the special cradle and get that smart charger, so I won't fall for the same mistake. Mike, thanks for the link. I also, watched few of your other videos, thanks a lot.
Re: Trend Air Pro
Re: Trend Air Pro
Phillip Medghalchi
Now, I need to know where to get the extra battery for lesser?
Re: Trend Air Pro
Re: Trend Air Pro
D.Hansen
You won't need one. If you make the charger it will recharge in about 2 hours.
Re: Trend Air Pro
Re: Trend Air Pro
Phillip Medghalchi
Thank you D. Hansen.
