a move to a new home and my wife's double by-pass surgery. She is doing well and I am thankful.
Lots of people to thank so I made a run of 12 maple french rolling pins with a solid walnut celtic knot. Very challenging but satisfying project. Four have already been sent to deserving kitchens.
To help with uniformity, since I don't do much spindle turning, I made a duplicating jig for the lathe.
I do have a 1/8" kerf saw blade so I used that to cut 2 parallel kerfs in the maple blank (to be filled with glued in walnut strips) with exactly 1/8" maple left between the kerfs. I got the offset for the second kerf by using a spacer between the sled jig and the maple blank. Due to the angle of cut, the spacer needs to be thicker than 1/8" and the proper thickness was found by trial cuts on waste wood. Naturally the walnut slats need to be exactly 1/8" thick and LIBERALLY slathered with glue....don't skimp on the glue. A weak glue joint will leave tear out on the rounded ends of the celtic knot.
I modified my cutoff sled for the jig and clamps. Note the stop block clamped to the saw fence to limit forward travel of the sled.
I used Corian cutouts to glue up on and used a lot of clamps. I also used small pieces of Corian as a clamping caul to seat the walnut firmly in the kerf.
To trim off the excess walnut after gluing I used another sled
Note that the sled is notched on one end to accommodate the ends of the walnut that "stick out" after glueing. Of course, the edge that registers the square blank is parallel to the saw blade.
Finally, since I have NO confidence in using a parting tool to remove the ends of a 24" long spindle, I made a cradle to allow me to cut them off on the table saw.
Between this and the tutorial, you can do it. Just allow plenty of time!
