Re: gluejoints
Ric Taylor
John,
This sounds like a project that you should take on with the "hope" that it will be successful, and don't be too surprised if it doesn't work out. As John Lucas said, it might just fall apart.
I recently did something along these lines knowing that it would probably fail, but I did it anyway. I wanted to sandwich sheet aluminum between pieces of wood.
I talked to a bunch of segmenters, looking for the adhesive that would would most likely be successful. After considering all of the advice and doing a bunch of research, I selected G/flex from the West System line of adhesives, because of the characteristics of strength and flexibility.
The aluminum sheet was roughed up with heavy sandpaper, and the wood was Sweetgum that was very dry. The Sweetgum in my area is very stable, and when dry, I've had no problems with movement in the past.
The project was successfully completed, and all was well ...... for about two weeks ...., then the wood and aluminum began to delaminate. I knew that it might not work, so there wasn't a big surprise.
The sphere is 5" in diameter with 1/8" sheet aluminum.
Ric
