removing 20 in sanding disc
gary clarke
Any one have any suggestions on removing a 20 inch 100 grit sanding disc from my disc sander? I have a 12 disc sander also and have had no difficulty removing sandpaper from it. I tried acetone, paint thinner and denatured alcohol and each made a huge mess. The sandpaper was klingspore 100 grit. It took over an hour and I still have glue on the metal disc. grrr
Re: removing 20 in sanding disc
Dick Coers
I like a single edge razor blade scraper followed up with lacquer thinner. It's still going to be messy. For tough ones like that, I like to use an industrial heat gun to warm up the adhesive while the disc is still in place.
robo hippy
Some rubber cements can have very specific solvents. I used a lot of Barge Cement, and mineral spirits worked best for it. Paint thinner, not so well. I was thinking a razor blade type scraper as well to take off the bulk. I hadn't thought about heating it first.
robo hippy
Mike Stafford
Mike Stafford
I have this problem with my 12 inch disc sander. It is always messy. I have found that heating up the disc before the initial removal helps but you are still left with gummy residues to remove.
I am able to remove my disc so I can place it horizontal. I then cover it with several layers of paper towels soaked in mineral spirits. Goo Gone works pretty well for the stubborn areas. I still have to use a paint scraper, the kind which holds a razor blade to get the worst off.
You can convert your disc holder to hook and loop but the results in use will be different.
Joe Mohnike
have you tried paint remover or white vinegar? Have used both and had good luck with them.
Just a thought.
Lan Brady
Gary,
After removing all the paper surface with a sharp blade, I use a 1/2" wooden dowel point, lightly pressed against the surface near the center. It genrates heat and melts the glue. slowly advance the dowel toward the rim.
Good Luck, Lan
