Kelton coring
Don in Central Illinois
Just tried coring for the first on a 17" walnut. Got three bowls and one very shallow funnel. One too thin and two too thick. But fairly satisfied with my first try. There is a definite learning curve.
Kelton coring
Re: Kelton coring
Jim Bodin
Have you tried YouTube - Dale Bonertz demonstrates the McNaughton Center Saver.
Re: Kelton coring *LINK*
jeff Willaford
Links to Dale's demo.... along with a number of other good coring tutorials are available on the Kelton Industries website.
http://www.kelton.co.nz/guides_videos.html
Re: Kelton coring
I've seen most of them and reviewed Mahoneys DVD, but actually coring is a little more difficult. But it is getting easier.
Re: Kelton coring
Josh Bowman
My experiences with the kelton after a few years was if I used it often I did ok with it. But a month or 2 later and I had to start the learning curve again. It might be the versatility of the tool (in other words:multiple ways to screw up) or my old age.
Re: Kelton coring
Jeff Smith
Dale's YouTube video is good - as is the article he wrote for the AAW Journal. Between the two of them, the information is there. That said, there's still a learning curve to go through. I found that, at least for me, the critical part of the operation is hitting entry point at the proper angle. Once the blade is in, it should self feed to the depth you want based on the angle of entry. The process is reasonably accurate.
There's two ways to get the angle: (I think this is probably a shortened sequence to what's described in Dale's video and article)With the blank chucked up, place the cutting tip at the depth you want (at the center line of the spindle) holding the blade between thumb and index finger (with your hand at the entry point - simulating the pins on the Kelton gate) as you pull the blade all the way out. When the cutting tip is at the entry point, look at the angle of the handle against the lathe's ways. Set the gate up so the handle makes the same angle and the tip should wind up in the same place you started in. Lately, I've been sighting down the handle to see what it's 'aimed' at and just aiming it the same way.
There was, at one time, a YouTube video that showed a similar process, but drawing it on paper. Haven't been able to find it for quite a while now. On paper, draw out the size of your blank and a center line extended out the length of the paper. Draw out the arc of the cuts you want to make for the cores. Take the blade you want to use and lay it on the paper with the cutting tip on the center line at the depth you want to cut. Line up the curved blade of the cutter to the line that represents the arc of your core. At the point where the blade will enter the cut, put your thumb and forefinger of one hand on either side of the blade at the face and pull the blade out until the cutter is at the face (it should wind up between your thumb and forefinger). The handle of the blade will be at some angle to the center line you drew. This is the angle of entry you need to use to get the cutting tip to wind up where you want it.
I used the paper first and, as long as you're reasonably accurate with your drawing, it gives good results. I used to keep a large pad of 20 x 24" graph paper handy just for this purpose.
It sounds a lot harder than it is. If you just do it right on the blank you've got chucked up, the whole process takes no more than 15 seconds or so. Once you get used to it, it actually makes sense. I found that I'd been 'overthinking' the process and once I got used to getting the angle right, everything is a lot simpler. Also, find yourself a nice fresh Big Leaf Maple - it's reasonably soft and easy cutting - cut it up into enough blanks to heat your home for the winter and start coring. Don't try to get any more than 3 cores from a blank and just go to town. By the time you're good and tired, you'll probably find that you've got it down. Then you can try to get 5 or 6 cores per blank if you want...
Re: Kelton coring
robo hippy
I put this up on You Tube a while ago. Another approach to coring with the McNaughton.
https://www.youtube.com/watch?v=xk-Z-scS84w
robo hippy
Re: Kelton coring
You might try this. I made an "aimer". Cut a piece of rigid clear plastic (acrylic/whatever) The size of your blank. That is, if your blank is 6" thick and 14" in diameter, make the plastic 14" by 6". I can be more than 14", up tot he swing of your lathe.
Come to think of it, this works with a chuck, but would have to be adapted for a glue block.
Draw a center line Across the narrow width, bisecting the long side. Chuck the piece so that the center line is the line of rotation. You can just pinch it between two of the jaws. Now mark the outer limit of the blank (7") out from the center line. Bring up the Kelton Gate. Put a knife in the gate and slide it under the piece of plastic, with the plastic horizontal. You can use a dry erase marker to trace the path of the knife. You can draw on the outline of the bowls you want and slide the knife and gate around until the path is what you need. Lock the gate in place, remove the piece of plastic, install the blank, cut it following the same path.
Re: Kelton coring
Barry Rockwell
Barry, now that's one I am going to have to give a try. Very clever!
Re: Kelton coring
Thanks, Not sure I explained it very well, but basically you can clamp a piece or rigid clear plastic between the jaws of the chuck and then slide the blade under it. You can play with the position of the gate, in and out and rotate it and watch the path of the blade. with a erasable marker you can draw on your blank and perhaps the shape of the bowl you want and then slide in the knife. Perhaps with a different color you could trace the path of the knife, move the gate and try again.
Give it a try, easier than it sounds. Come to think of it, I use a full sized piece, but you could just use the "front Half".
To move the gate out of the way to install the blank, I put a couple of tick marks on the ways and the banjo so I can get it back in the same spot.
