A55 Smoothing Plane
I like to carve feet on my turnings, but *LINK*
Keith Newton
Sometimes as I stumble along without first having had an inspiration, I'm not always pleased with the outcome. I'm still struggling with one, wishing I'd not done a couple of things.
The first one in the link below, is a good example. I have not done an end-grain turning in a long time, and was thinking about how easy it should be carving flutes, which I did before even hollowing. Then when I got down to the feet, because I've been using chisel marks in between the feet lately, I thought I would add extend the flutes below the step. I guess this falls under the heading of "Gilding the Lilly" heading, because now I'm thinking less would have been more. I think the fluting between the feet would have worked with smooth sides, or smooth between the feet with fluted sides.
Then, I sure wish I hadn't scorched the step. I'm thinking about carving that off, wondering if there might be something I can do to improve that, like more texture? Or just try to cleanly carve the scorching away, then carve the flutes away between the feet? Or should I just go drink a beverage and think about it?
Also, I know a lot of you have methods of keeping your lids from falling off. I included a shot of a simple method I've been using a long time. I turn a ring under the top, then carve / grind away most leaving two tabs on the end-grain, then cut only one key slot through the seat, off to one side of where the grain lines up. Since I turn green, both will shrink into ovals, which will limit the rotation, when they are close in size.
The two similar ones are cremation urns, for a son, and grandson for one of my friend / patrons.
https://www.flickr.com/photos/7391658@N03/sets/72157647296922197/
Re: I like to carve feet on my turnings, but *LINK*
Steven Antonucci
too much of a good thing?
steven antonucci
I think they're all very well done, but perhaps I also agree with you that there's something just a bit off with them?
In some cases, it may be the width of the foot (the two broader pots) that bothers me more than anything else? I think the feet needed to be set wider on the bottom? And maybe even a little bit lower in lift? (feet too tall?)
The tall one on the bottom certainly appears to be tipsy.
Love the locking lids and the kanji characters. Burned? Stamped? Inquiring minds want to know.
S
Thanks Steve,
Keith Newton
That has been my logo since 1980. It is KNewton up on end, usually on the outside if there is a place that seems to work, always burned in with a skew tip on a cheap pyro handle. Of course there is also the date / tracking number and wood type, which I sometimes make kinda cryptic.
Phillip Medghalchi
Keith the one with pot belly, the lines in the main vessel look very clean, but when you look at the feet somehow the lines don't match. I am thinking you have enough meet on the feet that you can trim/carve more of them cleaner to maybe to a triangular refined shape? On the first one you may want to carve away the flutes in the leg area. Too much details.
All of them look very cool though.
Steven Antonucci
KNewton, but in kanji, right? LOL
Re: KNewton, but in kanji, right? LOL
Keith Newton
Yes, back then I went through a faze where I was making a lot of stuff which had a Japanese influence, so when it came time to sign it, this sort of happened, and stuck.
And of course, the skew tip is perfect for the cuneiform shapes in most letters, but not too easy for curvy letters like e and o.
