Torn Grain and Vacuum
Stuart Johnson
I just completed a small hollow form and found I have a torn grain issue. After completing I check very carefully for issues while I sanded to 1200 and did not see any problems. I reversed and used a vacuum chuck to finish the bottom. By the time I finished it the form had wrapped a bit plus I never seem to get things running 100 percent true when doing the bottom. After I took it off I saw a slight ring of torn grain.
The wood is Hackberry which I guess is rather porous as it will fill cool when using the vacuum chuck. Can dust mask torn grain issues and then the vacuum suck it out revealing the problem? I have had rays of sunlight scratch a perfectly sanded bowl but not had this problem with torn grain before.
FWIW, the form has warpped enough and has no tenon so it can't be remounted for clean up.
Re: Torn Grain and Vacuum
Re-Mounting
Even warped (a bit), a jar should be able to be remounted between centers using a jam chuck and a small pressure block that can be fixed with either hot-melt glue or carpet tape. Not recommended for anything like recutting, but to sand out the torn grain ring at a slower speed I've done it this way.
Dick Coers
Just use a random orbit sander. I sand off the lathe all the time. Good lighting, a shot of compressed air, and a wipe down with naphtha or mineral spirits will be helpful to you for revealing problems. My eyes and bifocals just about have me to the point of using magnification before starting the finishing process.
Sanding dust will mask both torn grain and deep sanding marks. I wipe the turnings with a terry cloth rag between each grit. If I suspect a problem ill use compressed air to blow it off between grits. Back dry is very prone to torn grain.
