This month I'd like to pursue a question that was sent in by one of the readers of our bimonthly "News & Views" column in Woodworker West magazine.
USED WOODWORKING MACHINERY
What to look for, what to look out for, and the pros, cons and relative merits of new and used machinery.
I'm sure there is plenty of experience out there on all sides of this issue, and, as usual, we want to hear what you think. We'll distill your replies and include them in the next column, due out in mid October.
I bought a used Oneway 1224 in August. First you must know the retail price and what the average used price of the model you are interested in. Craigslist and E-bay plus the WC classifieds are a good places to start. Pay attention to the voltage requirements and whether or not it will work in your shop. I once came very close to buying a tool only to catch the 3 phase symbol on the motor.
Try out the tool and ask lots of questions. How long have you owned this tool, are you the original owner, has any repair work been done and if so, who did it? Actually this is a lot like buying a used car.
Remember also that motors can be rebuilt. I scored a really good deal by knowing that bad bearings can be replaced and bearing supply houses are usually much cheaper than a dealer.
I actively look for used equipment when the need arises and it has saved me $
First and foremost, if you can't turn it on, walk away unless the price is so low that you cannot.
Anyone devious enough to not disclose a problem is probably not going to be much help when you find it later on in your shop. I recommend reading the person as much as the machinery.
Finding parts for older machines isn't always easy. It may be working fine when you buy it, but if it breaks six months later, what are you going to do?
Lastly, a lot of older machinery was built before OSHA. If it doesn't look like its modern equivalent, there's probably a reason they changed the design.
You don't have to think back very far and you would notice the design model for lathes was for spindle turning. It has been relatively recently that lathe manufacturers have responded to the needs of the creative or artistic turner. Newer lathes have larger swing, larger footprint, slow speeds from electronic variable speed, more mass, more strength, sturdy accurate machining, engineering like moveable headstocks and fold away tailstocks. An old lathe would take a lot of upgrading and expense for what we want it to do today and even then you still have an old lathe. The limitations of an old lathe will sooner or later drive you crazy, my guess would be sooner.
Um,... well,... yes -- at least the better lathes that more serious turners tend to use.
I would say that many of the entry-level lathes available are perfectly terrible. Sure, we now have variable speed and reverse on some of the name-brand mini's and midi's, but none of them will hold a candle in a hurricane to an old Blount, or an old floor model Delta or Powermatic from the trade school shop market. These older models have easily replaced bearings, and some of the old Reeves drives have worked very well for many years.
Speaking as a green wood turner, sometimes just having an extra 400# of cast iron is of much greater benefit than reverse or variable speed. I have all of these on my PM 3520B, but -- aside from the safety issues of lower speeds which are critically important -- getting a little mini lathe down to 100 RPM or less becomes essential for out-of round blanks because it IS such a lightweight machine. When operating at low speeds, many of these entry-level variable speed machines have very little power to rough out a bowl blank -- they are essentially short spindle turning lathes that are OK for boxes and other small items, but still nothing to brag about when compared to an older heavy-duty floor model.
The machining quality on some of these entry level machines is pretty awful, too. I have a late 90's era Jet 1236 that is simply pathetic; the tool rest banjo locks up in one place, and slides freely a few inches away because the underside of the bed was never ground flat or parallel with the top surface. I've ruined some thin wall turnings trying to move it with the rest attached. I've also seen tool rests made from cast iron or cast steel, so they can break when stressed -- a very bad design.
When we get into any of the better quality name brand machines, I agree entirely with Lyle's assessment. However, I'd happily recommend an older machine over a shiny new mini for someone who wants a serious machine on a limited budget -- as long as they don't need portability. They can always replace the bearings if needed, and even upgrade to variable speed by replacing the old motor with a new 3-phase inverter-driven package. Not everyone with serious intent has the serious budget to get into the higher-end lathe market, and for them an older machine might deliver great value and utility.
Way back in 1936 I turned my first bowl in high school shop. the lathe was a big heavy cast iron lathe. Don't remember the brand. A few months later, after saving money fro a summer job I bought Sears cheapest lathe and a few tools. It was cast iron but was a big disappointment after the big high school lathe. I did have fun with it. I am now on my 10th lathe, each one bigger and better than the last one. There were a lot of crappy lathes along the way.
As late as the 80's top of the line lathes had a 12 inch swing. Tailstocks didn't come with a live center. Many were underpowered. They weren't designed for a heavy cut with a bowl gouge. My first floor model was an old Delta with a reeves drive. I did a lot of cussing at that reeves drive. It was crappy. My next lathe, bought in the early 80's was a General 260 which had a good reeves drive. It was considered top of the line then. Still it had a 12 inch swing and came equipped with a dead center on the tailstock. No reverse on any of them.
It's true that there have been a huge improvement in lathes. Even the lower priced mini or midi lathes are much better than some of the lathes I turned on in the old days. However, the biggest and best are very pricey.
One of the worst features of those old spindle lathes was that stupid gap bed.
But there weren't killing and maiming people. I think one of the unintended consequences of the new lathes (big swing, lots of power, heavy metal) is that people who have never turned before can buy a lathe that can kill them.
Well said Clay & turners need to be made aware of this!
In the past 10 years or so we have seen new lathes hit the market regularly with huge capacity, enormous swing, very powerful motors with reverse (argh!) all things on some turners wish lists. BUT they come with a very big downside - the lathes have the power & torque to get both inexperienced & experienced turners into very dangerous even lethal scenarios when certain combinations of hazards come into play. I believe that very few wood turners have the knowledge & skill to safely operate lathes like the prototype VL600, VB36 at their capacity. These large turning projects were the sole domain of pattern makers with proven technical competence not that long back.
From my research I have found at least 5 (confirmed) deaths at the wood lathe in the past 7 years or so and a number of reports of very serious injuries. We can not fully investigate what went wrong to cause the deaths of those turners but as a turning community we fully understand the hazards that turners are exposed to with hand turning.
We need to communicate & educate turners that the hazards do exist, the risks are very real but they can be managed! Apparently advertisers and vendors do not like gory stories - bad for sales!
Unfortunately not a lot has to go wrong to place a turner in a potentially lethal situation on not even very large projects as Lynne Yamaguchi's blog documents so well http://www.lynneyamaguchi.com/wordpress/
Good Point Clay and Geoff, Any lathe can hurt you. Try a belt driven 3000 RPM stupid stunt and it will leave a mark.
I talk to people ALL THE TIME that want to buy or already have purchased hollowing systems that are not in any way near safe for any skill level. Neither the manufacturer or the purchaser are aware they are treading on thin ice. The process is as important as safe tools. Trial and error with big stuff is the hard way to learn after the hospital visit or worse.
Bill, I can not or will not call out the bad ones. Word of mouth marketing will do that for me. It would not be politically correct for me to bad mouth other systems. It is a shame that some folks purchased systems that don't work very well and end up thinking that is "normal".
Hi Ellis, One thing to be aware of is many pieces of old equipment was designed to run on three phase power...there are ways around the problem, but it can be expensive!
