Drying Green Cherry
Drying Green Cherry
Drying Green Cherry
Tom Minehan
I have received several 12 in dia. x 16 in. long pieces of cherry. The tree was cut wn 1-2 months ago and the pieces were stacked. I notice they are starting to split on the ends. I plan to wax the end grain as it will be sometime before I can get to them.
My question is "Should I wax the ends cracks and all, or cut back to the end of the larger cracks and then wax"?
I have not worked with cherry before , feel fortunate that it was given to me, and don't want to "screw it up". Any guidelines will be appreciated.
Re: Drying Green Cherry
Dennis in Southern Oregon
Having had a similar situation with cherry recently, my guess is that nothing will save short pieces of cherry when cracking has already started, short of cutting it back to solid stock and turning it immediately. Cherry is not very forgiving in my experience.
Dennis
Mike Potts
Tom, first of all green wood is green wood no matter what species. go to these two links: http://www.johnjordanwoodturning.com/John_Jordan_Woodturning/Understanding_Wood.html
http://youtu.be/PrqvoGs2T_U
both give a very good explanation on handling green wood
Second this wood has sat for 2 of the hottest months of the year unprotected and just starting to show cracks. At this point no matter where you live the temps are heading down, the drying process is also slowing.
Third you didn't say how long "some time" is before you can get to it. But with 12" diameter and 16" long your max bowl is 12" so you have 2' on either end to cut back to good wood. That 2" is now helping to slow the rate of drying to the inter wood. My recommendation would be to wax the ends as they are, do what needs to be done, then turn your wood and enjoy it and not feel rushed. If in that time it cracks in another inch now you have a ten inch bowl, that no so bad.
Hey for most of us it's all about the joy we get from turning, not how big or how fast we can turn.
Be safe and have fun
Mike
Don in Central Illinois
Don't leave it in log form. Cut it lengthwise abd get rid of the pith. Coat the ends with a sealer. I use quite a bit if cherry and this has worked well in Cdntral Illinois. ( where I had to use the A/C and furnace yesterday)!
Brad Vietje
Brad Vietje
Agreed. Refer to Fig's 1 & 2 in the John Jordan article and be sure to split them down the pith -- or, even better -- make TWO cuts, each on about 1" offset from the pith, leaving a ~2" slab from the center with the pith running through this slab.
That slab can still be used for quarter-sawn boards on either side of the pith, or for spindle turning squares for all sorts of projects, so it does not go to waste.
If the pith is well offset from the center of the log (as it often is), arrange your cuts so the pith is in the center of the cut. In other words, you will get one larger piece, and one smaller piece, but both will be "centered" on the pith or the growth rings of the wood. That is FAR better than two chunks of equal size with the pith way off center (leads to two very un-balanced bowls), or with the pith running through one piece.
And DO coat them with Anschoseal or something -- it will not stop the wood from checking, but by slowing down the moisture loss, will reduce the checking and cracking and give you more time to get to these logs. OR -- if you have a huge chest freezer and an appetite for a larger electric bill -- you could toss them in the freezer.
Safe spinning,
Brad Vietje
Newbury, VT
