Thanks Rum and the Photo advice from others
Mike Potts
Made a table top photo booth, bought some lights, and a tripod. I'll never be a John Lucas when taking photos but it is a great improvement from my first try, always room for more. I took Rums wording and did my best to make it fit these bowls. Put it on Etsy and will hope for the best.
Thanks for the advice
Mike
One of a kind signed, dated, wood identified, and numbered pedestal bowl, this is one in a series of four hand crafted from a single carefully selected piece of Flamed Box Elder. This wood was handpicked by the artist from the edge of Lake Erie. Then turned into a hand crafted masterpiece for your table. Each bowl was single turned with its own shape and size to accentuate the unique and highly sought after flame character visible on these pieces. This is a natural coloring of the wood in response to specific environmental stimulus, storage in a dark area is recommended to maintain this character. Finished with three coat of Danish Oil, then buffed, and polished and finally a coat of Carnauba Wax nature’s hardest wax, that give it a deep, lustrous, long lasting shine. This bowl would make a great center piece for the holiday season.
Item# 287...8 1/2" diameter... 5 1/2" High.... 3/8" Wall thickness
Re: Thanks Rum and the Photo advice from others
Mike. The lighting does t look bad but the color balance is way off. It appear either green or orange. I'm on my cell so its probably not color correct but its usually close. It looks like you need to use either fluorescent or the tungsten white balance. My guess is you either used the daylight or auto white balance setting
Don in Central Illinois
Looks like old daylight film under incandesent lights. Way to warm. Also, try to use a draping material rather than having a horizontal line in the background.
John your right on the money
Mike Potts
I am taking the pic's with a sony HDR-cx230 not a lot of options, but if I ever start making a little money off my turning the first thing will be a better camera. thanks for the advice, as I said always room for improvement.
Rum
Pretty! We never see box elder up here, wish we did.
Wording is about as good as I could do with it, always a bunch of tradeoffs there.
No advice on the pictures - many others here are waaaay better than me at that (and always interesting to read:D). About the only pictures I get that are even half decent are in natural light taken in the morning or early evening outside (like you I lack a decent lighting setup for indoor pictures so I mostly just punt and work shoot outside when the weather allows).
White balance
Doug Wolf
Here is a page from your camera manual.
Try setting the white balance for indoor.
Re: White balance
Mike Potts
Thanks Don, I started out on white balance auto, then tried both indoor and outdoor, took pics then put them up on the computer, the outdoor gave the least amount of color distortion. I was looking at the menu and there is a place for exposure, I had it set at auto, do you think it would help to go manual then adjust., or does that effect the white balance at all?
Thanks Mike
Re: White balance
Exposure doesn't affect white balance. They are two seperated things. Yor lights might be flourescent. If you don't have a white balance for that the. You just have to try different settings to see what works best. Either that or get some lights with the proper color balance.
I prefer shooting art work in manual exposure mode but some cameras are just very hard to use that way.
Re: White balance Link
Mike Potts
John I bought 2 of these lights (see link) and used a halogen for my reflective light.
Sort of looks to me that I need a better camera. So if the on-line sales work out I'll have the money, but if they don't I'm more of a point and shot type of guy no need for fancy camera. thanks for advise
http://www.amazon.com/CowboyStudio-Light-Portable-Portriat-Photography/dp/B0034TUDD8/ref=pd_rhf_se_p_img_2
Mike
Well it doesn't tell the color temperature and they look like quartz halogen so they are probably tungsten balanced of course that's a guess but that would give your photos an orange cast if the white balance was daylight. Auto white balance will often correct pretty well for those but not a
Always.
