WILD CHERRY
WILD CHERRY
WILD CHERRY
Mike Potts
A friend of mine just cut down a large wild cherry tree, 15" diameter 60' . He is going to bring some to me. Has any one turned this, whats it like to turn?
Thanks Mike
Re: WILD CHERRY
Re: WILD CHERRY
Ron Bauer
Mike, you are a lucky man. Living in the northeast Adirondacks I have been able to get some cherry from time to time. My advice is to turn it as soon as possible because it cracks horribly if left even for a short time. It turns beatifully with a very pleasant cherry scent. Since the bark doesn't hold well I usually turn flat rim pieces but it does make nice hollow forms. Being hard and typically tight grained it sands and finishes well. You will enjoy turning it. I have a standing order for a ~12" cherry bowl but can't find anything big enough to make it. Happy turning. Ron.
Re: WILD CHERRY
Re: WILD CHERRY
robo hippy
Cherry always sells well, just the color thing I guess. I don't get much out here, but madrone, which has a similar color, sells better than myrtle wood. That might be in part because most turners don'e mess with madrone.
robo hippy
Re: WILD CHERRY
Steven Antonucci
Re: WILD CHERRY
steven antonucci
I turned most of this. If you look closely on the left, you'll see my buddy Don Scott standing there. :D
Steve
Re: WILD CHERRY
Re: WILD CHERRY pic
Mike Potts
Wow: Steve that must have kept you busy for some time
Re: WILD CHERRY
Steven Antonucci
2 years and counting
Re: WILD CHERRY
Re: WILD CHERRY
Dick Coers
Turns great, loves to crack while waiting to be turned, wet shavings on steel is the perfect situation for major rust pitting. Get a big can of WD40, some towels, and USE THEM A LOT!
Re: WILD CHERRY
Keith Tompkins
Re: WILD CHERRY
Keith Tompkins
Here's a 20"+ bowl I turned from the biggest cherry I ever saw..I got four bowl blanks this size from just one section of the trunk!
Re: WILD CHERRY
Very Nice, Keith
Mike Potts
Boy I am very excited to get the cherry, just had a call from my friend he has 5 pieces 30" long and 13" to 15" in diameter. I'll pick them up at the campground this Monday. I'm thinking of taking my chain saw and split them down the pith, hoping this will help keep them till I get the chance to turn them.
Mike
Re: WILD CHERRY
Re: WILD CHERRY
phillip Medghalchi
Steven, I hope your buddy wasn't part of your turning? :D
Re: WILD CHERRY
Re: 2 years and counting
phillip Medghalchi
Steven, you know if you have abundance of it you can always share. Remember our parents always said share your toys? :b
Re: WILD CHERRY
Re: WILD CHERRY
phillip Medghalchi
Mike, you can always swap like you mentioned for Mesquite?
Re: WILD CHERRY
Re: WILD CHERRY
Sergio
One of the best woods for turning and furniture.
As said green cherry has tannins that stain the iron and iron stains cherry.
Re: WILD CHERRY
Steven Antonucci
No longer abundant
steven antonucci
There is a group in my club that has made a significant dent in that tree, and the sawyer that took the main saw logs out of the tree on the right. For reference, that log is 35" across, and the part left behind was 8' long. The big limb to the right of it was used to teach my class at Peters Valley, and I probably only took 9' of it.
There is still a root ball and some large branches, and the two stumps from the tree on the left. However, all the easy stuff and primo stuff is long gone.
S
Re: WILD CHERRY
Re: No longer abundant
Re: WILD CHERRY
Re: WILD CHERRY
Mike Potts
Boy Dick you where right, I've turned wetter wood (box elder and cotton wood) but this cherry sure gets the rust going. I've turned three bowls so far, the first two need two more coats of danish oil then buffed, polished and waxed. the third I turned today, will sand tomorrow.
It does turn nice but I had to fight cracks on the last two.
