Ok fellow WCers. Years ago I purchased a hose clamp (4 inches) that had a magnetic "base" so I could position my dust collector hose anywhere on the lathe that I wanted. Now i need another one (or 2) and I can not find where I purchased them. Anybody out there know what I'm talking about and, more imprtantly, where to buy them?
I have been doing just what John says for many years. A rare earth magnet about the size of a nickel (remember what they are?) will hold a 6-in flex hose to the lathe bed quite nicely. Rather than epoxy the magnet directly to the band clamp, I epoxy it to larger washer that is wired to the band clamp via small holes drilled in the perimeter of the washer. I once had a failure of the glue joint between the rather small band and the magnet before I changed my approach.
I we t through every catalog I have and did not find one. My computer is down so I couldn't look to see if woodcraft has them online. They are t in the paper catalog.
I just checked the on-line Woodcraft catalog - apparently they are not currently offered. Wen through anything related to 'magnet' and all dust collection/hose accessories...
My local Ace hardware sells these rare earth disk magnets in several sizes including the 0.7 inch size that I used. I believe that Ace refers to them as super magnets.
Dick, you should be able to find the bands that Dia. in the plumbing dept. at Home Depot or Lowe's and then find an old speaker magnet like they said (go to the local sound store or the guys who do car window tinting and they have them all day long, because some kid always want to have a bigger speaker, they usually dump them in trash, You just bring it home and then knock off the brass ring around it being careful that you don't crack open the magnet) and then you can epoxy it to the band. I even found the band that has a plastic coated turn wing nut. Again, in the plumbing dept.
