Kiln
Kiln
Kiln
Don in Central Illinois
I used my old dishwasher, ala Russ Fairfield, but not sure how to use it properly. With a 100 watt bulb it stays around 85 degrees. Is this hot enough? Need some guidlines please.
Re: Kiln
Re: Kiln
Dick Coers
85 is okay after the wood has lost the early moisture, but in my opinion, too cool for latter. It's going to take quite a while to dry 1" wall thickness bowls. You can always add another bulb. If you are drying bark edge bowls, you have to get it to 135 to kill bugs and larvae.
Re: Kiln
Re: Kiln
Bill Jacksonville, NC
More than temperature air circulation is your friend assisting water in wood to evaporate. Then again too much air circulation & heat can speed up drying process to the point of wood degrade.
Finding a balance of air circulation & constant temperature is key to successfully drying wood. Small fans and single light bulbs been used forever in homemade kilns. Some people put light and fan on timers to cycle on and off automatically.
Have seen the reult of too many lights in a homemade kiln. Fellow could not understand why people would not buy his cracked bowls filled with various fillers.
Re: Kiln
Re: Kiln
I guess I'll add a 40 watt keep adding toll I get it right.
Re: Kiln
Rob Wallace
Re: Kiln
Rob Wallace
Don - remember that in using a kiln you want to ramp up the temperature slowly as the wood continues to lose moisture. For the first several days/weeks, the temperature will necessarily be lower as the moisture is lost, and (hopefully ) slowly vented to the outside with admission of cooler, dryer air. After most of the moisture has been lost, the kiln temperature can be stepped-up to 125 to 130 or so, but the key is..... S L O W L Y.....
You may need to add more bulbs to provide additional heat, but you should not expect a kiln full of wet wood to achieve 120-140 degrees immediately. A lot of energy has to go into evaporating water; once the water has been lost, the temperature will rise naturally when there is less water being converted from a liquid (or a molecularly-bound liquid) to a gas....
BTW - the adage that "the denser the wood, the slower the drying" holds, so don't vent that kiln too rapidly. You're looking for a gradual, controlled loss of moisture.
Good luck, and report back about your results...
Rob
Re: Kiln
Re: Kiln
Rob, I think you answered my question. When I first put this together a 75 wattbulb built the tempersture to around 90. When I put in a fairly thick bowl, it never got above 80 - 85. I'll kerp an eye on this and see if tge temperature rises ad the bowl loses moisture. Thanks.
Re: Kiln
Re: Kiln
John Veerkamp
Experiment with higher wattage bulbs rather than putting in more bulbs. Keep a selection of wattages up to even 200 watt on hand and monitor temp regularly. A remote read thermometer works well.
Re: Kiln
Re: Kiln
I bought a small meat thermometer, drilled a hoke in the door and can read temperature without opening ghe door.
Re: Kiln
Rob Wallace
Good Kiln Thermometer/Hygrometer
Rob Wallace
This is the remote-reading digital thermometer/hygrometer I got for my kiln:
http://www.fishersci.com/ecomm/servlet/fsproductdetail?storeId=10652&productId=4432498&catalogId=29104&matchedCatNo=1464984&fromSearch=1&searchKey=thermometer|
(Sorry about the obnoxious URL!)
This device measures temperature and humidity simultaneously via a remote sensor that is placed in the kiln. You can buy similar devices on eBay and other places. Search for an "incubator" thermometer and/or hygrometer - these are used for measuring incubator conditions for hatching eggs of birds and reptiles. Just be sure to check maximum and minimum temperature ranges for the device you buy. For example:
http://www.ebay.com/itm/Digital-Egg-Incubator-Thermometer-Hygrometer-w-Remote-Sensor-/141344688068?pt=LH_DefaultDomain_0&hash=item20e8ccc7c4
Rob Wallace
Re: Kiln
Re: Good Kiln Thermometer/Hygrometer
Skip Beardsley
Don,
I have a home made kiln which is 2ftx2ftx 4.3 ft. There are four shelves in it and I really load it up with as many bowls as I can get in. Sometimes I sticker small ones on top of each other.
I have a computer fan, about 3x3 which I got at Radio Shack and a 100 watt bulb. The cycle is three weeks. First ...... fan on six and off six. Second.... light on six off six. Third.... both on 24/7. The humidity is monitored by a thermometer which also gives humidity. There is a window in the front and a four inch hole on the top with a slide gate much like you would find on dust collector systems.
All the bowls are cut green and sizes are mixed to get the most into the kiln. My meter only goes to 22% on the high end and most of the bowls are above that when they go in. At the end of the cycle they are at six percent. Cracking is very minimal. Haven't had a crack in over a year.
Hope this helps.
Skip
Re: Kiln
I'm wondering......
Back in the day, my grandfather used to dry tobacco in a barn with open fires below. (Dark tobacco) The tobacco was left in the field for a few hours after cutting it to let it wilt. then hung loosely in the barn. Then the fires were started and kept very small and smokey. The tobacco dried slowly and he monitored the temperature. Near the end the temperature would go up dramatically. What was happening was evaporative cooling was keeping the temp down, but when the last of the moisture was gone the temp would rise and the fires were extinguished quickly to prevent burning the barn down.
So, is the same thing happening in these kilns? If the temp go up at the end of the cycle for no apparent reason, does that tell us the evaporative cool has stopped and the wood is nearly dry?
Re: Kiln
Rob Wallace
Re: I'm wondering......
Rob Wallace
Barry -
In short - Yes - same thing happening as you kiln wood. Latent heat of vaporization of the water ('free' and 'bound' water in the wood) limits temperature rise until most of the water is gone and vented from the kiln. Then things get warmer quickly.
BTW - When drying wood too quickly, an outer "shell" of very dry wood can trap moisture deeper within the wood, creating undesired stresses within the wood itself (....let alone to the kiln operator). This is termed "case hardening" and should be avoided at all costs, which is why slow temperature rise with gradual moisture loss is desirable. In some cases where case hardening is detected, operators will actually spray the wood with water and humidify the wood (i.e. with no venting) to relieve the stresses and permit more even drying. Don't rush the drying process by pushing the temperature too high, too fast; these small kilns should work well in drying the kiln contents with minimum degrade if vented slowly with moderate temperature rise over the drying cycle.
Rob
