I was turning a 15" platter this morning While I was sanding it touched the outside with the back of my hand and the friction burned right through the skin. I barely brushed against it Burned me about like when you brush a clothes iron. Ouch.
These posts will have to be short for a while. Lightening damaged my computer a d it might be 10 days before I get it back. Ill be using the phone so messages will be short and probably lots of typos.
From my construction days, The job ain't finished until BLEED has been declared. Now that I am on blood thinners I seem to bleed all over everything. You have what I call a rim burn. I wear a leather glove with the fingers cut off on my left hand. (A habit we have discussed many times here.) On a platter I cut a very thin sharp rim. Turned the lathe off to look at it. Reached out with my gloved hand and stopped it. That edge sliced that Glove like a knife. Actually ended up with a cut like a paper cut on my hand. If I had not been wearing the glove I would have needed stitches. Or maybe I would have had enough sense to not touch it.
There is some medicine they advertise on TV that says don't take this if you have an open wound. I doubt they are talking about the tiny nicks and scratches I usually have, but if they are, I will never be able to take that stuff. I always have a cut somewhere.
