Chatter tool, and texturing tool
phillip Medghalchi
Dose any one has instructions as how to make them. Please?
phillip Medghalchi
Re: Chatter tool, and texturing tool
Brad Vietje
Hey Phillip,
One way to make a chatter tool is to sharpen a 3" long piece of stiff spring steel, and simply hold it in Vice Grips. Thinner steel for softer woods, and thicker, less flexible steel for harder woods. You can vary how much steel protrudes out of the pliers, and you want to rest the jaws of the pliers on the tool rest, not the springy steel.
Others here will know much more than I about good sources of appropriate steel alloys. I just used a dull Sawzall blade that had been shaped on a grinder. Make one with a "V" point, and another with a small radius at the tip, and have fun experimenting with rpm, angle, direction, etc...
I own and often use the Dennis Stewart chatter tool, but I've also used the Vice Grip & power hacksaw blade method, which works just about as well for me.
I'd love to make a rotating texturing tool -- I'll keep a lookout for a good recipe for that.
Safe spinning,
Brad Vietje
Newbury, VT
HeatherAinAK
Here are some links I found when I was making one.
http://www.crwoodturner.com/chatterwork/index.html
http://detroitareawoodturners.com/yahoo_site_admin/assets/docs/Making_a_Chatter_Tool.312141908.pdf
http://www.aawforum.org/vbforum/showthread.php?6602-Home-Made-Chatter-Tool
http://www.syzygywoodworks.com/news/2009/11/12/homemade-chatter-tool/
http://familywoodworking.org/forums/showthread.php?2487-Homemade-Chatter-Tool
I googled homemade chatter tool and came up with a bunch.
Heather
Ditto what brad said. I found used blades they use to saw the metal 2x4's work great. I found them at construction sites where they are doing office buildings. Probably my any good small saw blade would work. I think I may have plans for making an adjustable handle Ill be at my computer this afternoon and will look
John Stegall
More links: http://nebula.wsimg.com/6747bfdd52b8f03379f95f1a8b8c191d?AccessKeyId=8E1EC0DC707F1FE36FCB&disposition=0&alloworigin=1
http://www.scrollsaws.com/WoodLathe/chattertool.htm
http://nebula.wsimg.com/22d593c2f4832133fbafcfa3a9e61a67?AccessKeyId=8E1EC0DC707F1FE36FCB&disposition=0&alloworigin=1
steven antonucci
I have made bunches of these, and my favorite is made from an old bow saw blade. Just the right amount of thickness, hardness, and springiness. A jigsaw blade works too, but you need to let it out longer because it is thicker.
They don't need handles, but you can make them simply by screwing the end to a block of wood. I made tons of tops with just vise grips, but I got tired of packing them for demos, so I made the little handles.
As for knurling wheel cutters, it isn't rocket surgery? All you need is for the cutter to be on the end of a stick and able to spin freely. I buy the Sorby cutters for $12-15 ea, and I am off and running with a "close enough" through bolt as shown. I may break down some day and make something with closer tolerance, but what you see in the spirals was cut with a slightly sloppy fit...
S
phillip Medghalchi
Thank you John.
phillip Medghalchi
Steven, would a band saw blade of 1/2"or 3/4" work? and I have a gear wheel that I can add the pic. here for it.
I had no luck with bandsaw blades
steven antonucci
I tried, they all broke very quickly. The bowsaw blade has been in use for 10 years
S
I made several different chatter.......
JamieDonaldson
...blades from the steel straps used for heavy duty shipping purposes. Several of the sawblades I tested were too brittle and broke.
Terry Quiram
I have made many of these. I use 1/2" tubing with 5/16" id. Spring steel is from a piece of industrial band saw blade. I drilled and tapped through the end of the tube. (its easier to drill and tap this way) Used 2 set screws. I sharpened the end before bending.
