3 bowls done this morning.
I had to turn these Oak bowls for a friend. I wrapped the wood in plastic bags as soon as I got it. I was worried about cracks because it set behind their business for several days before they called me to come and get it. Then I had a million projects up front to finish and that was just before the motorcycle wreck so the wood set in the bags for about 2 months.
Once I cut the moldy ends off the wood was fine. 2 of them had very minor cracks. I kept a close eye on them but was able to run the lathe fairly fast. Got clean cuts with no tearout so sanding the bowls when they dry shouldn't be hard.
the 2 with the cracks are about 3/8" thick the smaller one is 1/4" I put them in paper sacks to dry because they may not be dry before I have to start the proton beam therapy and this should keep them in good shape until I finish that and can get back in the shop.
I still haven't had time to put up my netting to keep the shavings at bay. These were small bowls and I still had shavings 8 feet away. I covered the table saw, jointer, and horizontal bandsaw. Still had some shavings on the bandsaw table but brushed them off for the photo so they wouldn't rust the table anymore. Bear in mind this is half the mess I usually have when I turn bowls larger than 9".
