ADVERTISE HERE - FREE TRIAL
OT Bless the engineers at Honda automotive!
Dick Coers
Did a front brake job on the wife's 2008 Civic this morning. 90,000 miles on the factory original pads, just barely touching the one squealer. It took less than 1 hour, including the test drive! After removing the tire, you only have to remove 1 bolt to change the pads. The piston is held in one assembly that pivots out of the way when you remove that one bolt. The pads are held in with friction in a separate yoke. When the piston assembly pivots back over, it's all buttoned up! I've done a lot of brakes, never like this! This is what I call engineering excellence! I drive a Honda Fit because with fold down back seats, it's like a van. I may just never drive another brand!
Re: OT Bless the engineers at Honda automotive!
I own my first Honda. A 2013 CRV. So far it's excellent with only one problem. I'd love to have a repacement key in case I lose this one. $164 from the local key guy and Honda wanted $240. That verging on obscene since it's a very simple piece of electronics and I'm not sure if there are any advantages to the laser cut key.
OH Honda's not the only one, my last ford was just as bad and my friend who owns a Prius said his replacement keys are $300.
I have owned a bunch of Honda's over the last forty years. Rally nothing bad to say about any of them.
My 2003 CRV was t-boned about two weeks ago and that finished it off. (D@mn Virginia law. The insurance company essentially bought the car from me wholesale and I have to buy one retail) I have been trying to buy a replacement and have learned that something like a 2007 CRV with 150,000 miles sells for $10,000.
So, it'll be a new one for me.
John, which model did you get. LX or EX or EXL?
Dick Hines
Dick Hines
I bought my first non American car last year. A Toyota FJ. I like it so far. Lots of room with the flip down back seats. If the front seat is all the way back anyone under 6ft can't reach the wheel. Not the best gas mileage but I can live with it.
I was going to sell my 2001 F150 but decided to keep it for hauling trash and wood. And I have enough red neck in me that I don't want to get rid of my truck. It only has 180,000. Shoot, it's like new.
Nissan too
Tony - Memphis
My wife's Nissan 350Z has a similar arrangement. Very quick and easy pad swap. I buy factory pads and they even supply two different grease packs for the assembly.
I now drive a hybrid - shouldn't need brakes for a very long time! Not sure how tough they will be...or not.
Tony
Ric Taylor
Ric Taylor
John,
There is a sign in the window at my local Ace Hardware that says they duplicate car keys with the computer chips in them. I don't know what they charge, but you might want to look into that.
Ric
Keith Tompkins
Keith Tompkins
Dick, Eh-h-h-h-h....You're not quite finished yet..When you remove the bolt from the caliper, you will notice the pin floats in the caliper. Hopefully, you slid the pin out, cleaned it, and reinstalled with new caliper grease. If the pin doesn't float freely, there is rust accumulated under the rubber inserts that hold the floating pin (Prevalent here in the North). Same with the stationary pin. The pads must also move freely; sometimes rust gets under the anti-rattle clips and makes the pads difficult to install...Pull the clips if necessary and clean out the rust. Failure to deal with of these problems will shorten brake pad life dramatically. (Former certified master technician)
Speaking of Honda engineering...My CB750 motorcycle was an engineering marvel in its day, modern even by today's standard..43 years later. 4 Cylinder engine, overhead camshaft, hydraulic disc brakes, 5-speed transmission, thoroughly modern electrical system, dry-sump lubrication system..etc. Capable of 125 MPH right out of the box, and with reasonable care, easily capable of reaching 100K miles without any major repairs. The CB750 was responsible for the demise of the English motorcycle, and bankrupted Harley Davidson. Oh Yeah...I drive a Honda Fit too!
Dick Coers
Thanks for the tips Keith. Well, I didn't grease the pins, but everything was floating very easily. After I slid the piston back, I had to slide the piston assemblies outward to center them. Very little effort needed. The pads slid right in the clips, no force needed. I'll keep an eye on the wear. I guess I still work on cars like I was taught to work on farm equipment when I was a kid. Get it working, get it back in the field. I was working on the Civic under a shade tree too. LOL
I did they can't. They also can't duplicate the laser cut keys.
Dale Gillaspy
Keith, I have a 1990 Goldwing that I love, similar engineering, but the electronics are a bear. I have an open ground somewhere that I can't find, and can't find anyone who will work on it.
Other than that, I think Harley ran themselves into the ground, then sold out to a bowling supply company....different story, though....
Bob Macgregor
My first car, a '68 Datsun 510, was even easier. The first front brake change, I watched the mechanic while he pried the brake pads apart with a big screwdriver, popped the clips holding the pads in place and put new ones in. The whole brakes change took less than 15 minutes, including lifting the car and removing/remounting the wheels.
Next time, I did it myself; my only tools for the job were a jack and a tire iron.
Bob
Keith Tompkins
Keith Tompkins
Dale, what kind of electrical problem....? Give me an email, I might be able to help trace the problem.
