Root ball *LINK*
Root ball *LINK*
Root ball *LINK*
ILYA Z
Hello everyone
First post after a long hiatus...
Picked up this root ball from my neighbor. Now trying to figure out what to do with it.
It might be apple but I am not at all sure about that. It's about 16" in length and 16" in diameter at its widest. The wood seems to be solid (I think the tree was alive when it was cut)
I posted some photos of it plus a short video (http://youtu.be/76y9eWUYumU)
Since I have never turned a root before, I have a few questions:
1. With a blade screwdriver and a garden hose I managed to remove a lot of sand and rocks from its many crevices. The root looks like a cavern so I am sure that is still crud inside. Do I absolutely have to get it all out somehow before I put it on the lathe?
2. I was advised to use a power washer. But I am not sure it would be powerful enough. I had to literally pry some pebbles out with the screwdriver and I doubt a power washer stream would be powerful enough to do it. Other ways of preparing this piece before putting it on the lathe?
3. Would you ever put it on the lathe even if clean?
Thanks
http://s941.photobucket.com/user/ilyaz73/library/Root%20ball
Re: Root ball *LINK*
Re: Root ball
I would cut it up into smaller pieces. The grain will still be really nice and you can more easily deal with the smaller stones and such.
Re: Root ball
ILYA Z
How would you recommend cutting it? Cross-grain (or the trunk) or along the grain or in some other way? Thx!
Re: Root ball
I'd just look for sections that might give you a good shape whatever that might be. It will be hard to tell which way the grain runs on a root burl because usually it's pretty curly. Not always however and that's where it gets interesting. If you cut it for a hollow vessel for instance you may find you have a void in one side. Same with bowls. I suspect after you cut one or two you'll have a better feeling for what you can make out of it. I would wax the blanks and put them up and think about it for a while. You may come up with some other good shapes to use.
You really have to use your imagination. Let your designs run free and don't limit yourself. None of us can really tell you what shape to cut because it's impossible to see all the possibilities in 2D.
Re: Root ball
ILYA Z
OK thx
By the way, is it a BURL or a BALL? I thought it was a ball since the root piece is sort of shaped like one. But I presume since it's a root then the grain can go every which way so I guess it would be a burl. But I thought burls are only tumor-like irregular growth things around a tree trunk or root, not the root itself. So is it one, the other, both or depends?
A root ball like this often has......
JamieDonaldson
...burly sections of grain, and experience is the only aid in learning to deconstruct the useable material. Get ready to sacrifice a chainsaw chain, and imaging the forms trapped inside the ball. ;)
Re: A root ball like this often has......
phillip Medghalchi
Ilya, I just had one and it's very interesting to play with it, and there is no way like John said your gonna know what your dealing with, specially if it is a root. You sound like hat I did (trying hard to figure out what to do) until our good friends helped me to realize that the bottom line is that your piece was destined to end up in the trash or recycle (if lucky). Now, you didn't pay for it and so go and experiment and make us proud as what you come up with. Like they said above let your imagination help you and if it doesn't make it due to the holes or hidden crevices ( you may run into them as I did I mine), then remember you tried and you'll learn something from it. On the next one you'll know exactly what you are looking at(somehow) and you will know how to cut it to your liking. After all, you are trying to salvage it. but, don't forget that it may cost you a chain, because of pebbles and the hidden dirt, but it's worth your learning. It can't be any worse than getting a bad quality food and then you can not put it back on the plate and return it for a refund, a chain will cost you about $10.00+, however the experience will last you a life time.
So, next time we'll see your creations?
I gave up on root balls.....
Dick Coers
and you may too if you hit a rock or two. I killed a chain once, killed a bar once when I got into lots of sand cutting a palm root ball, and clipped a rock with a bowl gouge. Turning sand, dirt, and rock will really be bad for equipment! Then consider it has to be turned quickly if it's apple, because it LOVES to crack.
Re: I gave up on root balls.....
Me too, Pretty much.....
I took down a maple tree in my yard and turned the root ball. First, I power washed it. Not a pleasant situation. More dirt and mud on me than the root ball.
Then I picked out rocks. I ruined a chain.
I turned one bowl about ten inches in decimeter That was very frail, almost more voids than wood. Gave it to my girlfriend's sister for Christmas. Amazingly, she found a clear glass bowl that fit inside it perfectly. Could not have been a better fit if I had tried. She uses it at parties as a candy bowl or some such thing.
I managed to turn two more bowls Right out of the middle of the ball, both about fifteen inches in diameter. One was turned as if the tree grew right up out of it. I still have it. An interesting bowl. The other one was similar and I gave it away to the lady who kept my kids when they were little.
It was a lot of work.
ILYA Z
It may take a while to produce any sort of finished product. What I can probably do soon is to cut the thing up and report what I get.
Thanks!
ILYA Z
I am OK with losing a chain. It's old anyway so I need an excuse to buy a new one.
I have to admit: after a couple of unusual pieces I tried to turn blew up on the lathe I am a bit paranoid about turning anything with a lot of voids. But I guess this would be a good chance for me to face my fears. :)
ILYA Z
OK so I guess I can call it a BARL :)
phillip Medghalchi
Ilya, Dic, and Barry got a good point, if you are afraid of bow out and voids falling apart and coming off on you then take strapping tape (mine is white, and it has filament inside it (bit little more expensive than other tapes) then only when you are going to hollow out the inside, wrap the outside very well with this tape, The reason is that strapping tape will not come loose and will hold on very well. if your bowl is tapered which it will be towards the bottom then you make sure that you overlap each layer and the other thing is that you have to wrap the tape around on your lathe clockwise, so when the lathe is turning towards you it automatically tightens the tape around the piece and it gets tighter as it turns so i t won't come off. Then you start hollowing, however, what Dic, and Barry said are true and you never know what you are getting into and turning. However, this will put your fear at rest. Oh, you have to do this at one side of the line of fire, because you are not looking at wood coming off, you a re dealing with a possible little pebble or rock flinging and those are not joking stuff to hit you. However, as John Connery says it's improbable, but doable.
Hope you will have fun, and be safe.
