production run
I am about 50/50 on production turning. I don't like doing it but it does have it's good points. When you turn the same thing over and over you get really good with the tools. You get to practice changing the cuts very subtly to see if you can get a cleaner cut. You learn to relax which doesn't tire you out so much and at the same time it helps get cleaner lines to the cuts.
I also played with sandpaper trying to get cleaner line free sanding. ONe thing I learned was worn sandpaper leaves more errant lines. You know that one deep line that you only find when you get down to 400 grit. If the paper is fresh it doesn't leave those and each grit sands down the previous lines. OK I knew you should use fresh sandpaper but we all tend to push it, especially when turning multiples.
The heads of the mirrors averaged about 33 minutes each, although I think I took a coke break in there so they were probably turned faster. The handles went from 10 minutes to about 15. Broke one. It had a weak point near the thin part of the handle. I though something was wrong because it chattered way worse than the others. The grain ran across the thing point behind a little knot. That's where it broke.
Now I just have to drill the holes, glue in the handles and put the final finish on. You can see my other projects. Fixing the lawnmower is first when the parts get here.
