I did consider it
Jim K from Trappe, PA
Steve, I thought about a sacrificial non-pencil core, as well as a hollow core. I would have had to cut down pencils and glue up the top and bottom, which would have given me the correct internal diameter for the outer shell, then I would have to make the inner core to that size, then glue up the outer pencil shell, while incorporating the top and bottom. With the pencils being hexagonal, I thought it gave me too many chances to mis-measure and screw up on the core size. It used more pencils, but was lower risk.
Besides the glue used to connect the pencils, no I did not use any filler glue. I hollowed out the vessel, but only to about ½” thickness, because I was concerned about hitting a weak point and blowing it up (pencils are not all built to high specs!) . From the outside, it looks thin ;-)
