Rut-Row! Help Needed ASAP
Brad Vietje
OK, Now I've done it... I read here and elsewhere about using PVC plumbing fittings for a threaded top on a cremation urn, so I did (and the committal service for my mom is Saturday).
BUT, Tab A does not really fit into Slot B.... seems these fittings are tapered somewhat, so while they "fit" and the threads engage and make about 2 complete turns, then they bind up, and I can't get the finial thing in all the way. OOPS!
So, now I have to either grab the threads and turn the plastic away and try again, or maybe there's an easy way to ease the threads a bit with a pipe threader (?) I also need to clean up some of the excess epoxy
Practical advice will be most appreciated!
Here's Tab A:
And here's Slot B:
Here's the mis-fit:
...and the entire situation.... no photo booth these days, so a window recess will have to do for now:
Thanks in advance for all your ideas!
Safe spinning,
Brad Vietje
Newbury, VT
