Bostik TopCote Aerosol
Jim Evans
Is there anything out there like Bostik TopCote Aerosol 10-3/4 oz., but less expensive than $26 a can?
Jim Evans
Re: Bostik TopCote Aerosol
I pay less than $26 for a gallon of my lacquer. Of course I had to buy a compressor and spray gun but I guess they've paid for themselves by now.
Jim Evans
John, do you use lacquer to top coat your table saw? I was wanting something to top coat my saw and cut down on corrosion.
Chuck Engstrom
Hi Jim -- Several years back I scoured the top of my bandsaw table with mineral spirits and a green ScotchBrite to get all the junk off it. Then I gave it a couple of coats of Minwax Wipe-On Poly with a paper towel, and since then have found that this has held up very well. It may not have all the gee-whiz ingredients of other products but it seems to do the job plenty quick and cheap.
Best to all -- Chuck
Johnson Paste Wax
Mike Potts
I've used Steel wool and wd-40, then paste wax for years. It doesn't last forever, but it's pretty fast and cheap. My old saw was 37 years old, and I came into a little extra money and bought a granite top saw, no more rust for me.
Jim Evans
Thanks everyone, I have used the top cote and really liked it, but someone used it as a wood finish and left me without. It only cost $19 a can, but with $7.50 in shipping it leaves me without.
I'm going to use the Johnsons paste wax as suggested.
Mark Trenier
I also love top coat--but I found dry silicone aerosol at Farm and Fleet here in Wisconsin for way less than that. They have it at Amazon too:look for Liquid Wrench dry lubricant. Never had a problem with it getting on any project I've made with the table saw or jointer.
Hope that helps.
Steve Worcester.
Topcoats for a table are great, but silicon is not a good thing in my shop. Penetrates into the wood too well and inhibits almost all finishes.
I don't use anything. But if you are going to cut through it a reasonable amount , then power on.
phillip Medghalchi
Jim, look here:
http://www.amazon.com/Bostik-GlideCote-formerly-TopCote-10-75/dp/B00DAN8P2O/ref=sr_1_1?ie=UTF8&qid=1408579107&sr=8-1&keywords=bostik+topcote
and free shipping:
http://www.amazon.com/Bostik-BladeCote-formerly-DriCote-10-75/dp/B00DSW7DWK/ref=pd_bxgy_hi_img_y
Jim Sorry had finishing on the brain because that's what I've been doing all day. I just use Johnson's paste wax I put a coat on about once a year or so. I run around the room and coat my workbench, jointer, bandsaw, table saw, planer table, and anything else that either needs protecting from corrosian or protection from glue. I also use it on my hand saws and planes.
Emerald Ash Borer
Jim Evans
Thanks Phillip, I bought one for a little less that the price above, and that includes shipping. $17.58
Re: Emerald Ash Borer
phillip Medghalchi
From the same outfit?
glidecote
Jim Evans
yes
Harry Robinette
Jim
I been using PG2000 on all my machines for almost a year and love it. My banjo and tail stock slide easy but lock down tight,wood slides on my band saw and table saw better then ever. I spray a little on a paper towel and rub the steel with it wait maybe 2 or 3 min and wipe off almost all of it. Oh ya I do this at the end of shop time so it drys better over night.Next day wipe with a paper towel and good to go,last about 60 to 90 days then repeat. I got a lot of moisture in my shop this year from all the rain and the steel in my shop I have to work with all started to rust but my machines are all fine. I'll keep using it.
As always just my $.02
Harry
easyglide
Jim Evans
Thanks Harry, I'll keep that in mind.
