Pen Turning Questions
Warren White
I have just begun turning pens and have a few questions.
First, the pens I have are Woodcraft Slimline pens, and I have their recommended bushings.
When I turn the pens, I turn as close as possible to the OD of the bushings, and sand (100, 220 then 400), even closer. Then I clean with Acetone. I prefer the CA glue finish, and put a couple of coats of thin, followed by about 5 coats of medium. Then I sand with 400 grit until I have a uniform matt finish with no shiny places. I then go through the range of dampened Micro Mesh from 1500 through 12000. The finish is spectacular!
First question: Perhaps due to the amount of CA glue, the center decorative ring is a bit below the surface of both mating ends of the pen. I am afraid of turning below the bushing, because on a slimline pen, there is little wood left as it is. Suggestions?
Second question: (This may well be a bit controversial, and if it is, I apologize in advance.) Since I really like the Slimline pens, are there brands that may be better than others that you would recommend?
Last question: I have a barrel trimming bit with a center pin for 7 mm pens. I see folks putting the bit in a drill and holding the blank in their hands and forcing it onto the bit. I have used the head stock of the lathe to do the same thing, even more safely, but folks are still holding the wood against the bit by hand. Are there other (or better) ways to accomplish this step? It seems to take quite a while to accomplish, even when I am quite careful in cutting the blank to a length close to the barrel length.
Newbie questions, I know, and I really appreciate your advice. This is a REALLY fun hobby!
Re: Pen Turning Questions
David Walser
Lots of good questions. Here are my responses:
1st: Since you are turning your blank even with the bushing (which is the same diameter as the center band) the CA finish will cause the finished diameter of the pen barrel to be larger than the center band. You have basically three choices: Put on a thinner coat of CA, turn the wood down below the bushing, or chamfer the end of the barrel so that the difference in diameters isn't as apparent.
My approach is usually the latter. I shape me pens with a gentle curve and then chamfer the end (after the CA coat has been applied) using the long end of the skew. It also helps to separate the bushings from the blank. While my pen barrels are proud of the center band, the chamfer makes the transition look nice and it feels nice in your hand, too.
2nd: You'll find that pen turners gravitate to a couple of suppliers that they've had good experiences with. My personal favorite is Craft Supplies USA. There are several good ones. Most carry a range of pen kits that differ in quality. (Think of the difference between a Ford and a Lincoln.) Find a good supplier (one who knows a lot about pen turning and stands behind their products) and ask them about the advantages and disadvantages of each of their lines. The higher quality 7mm kits will offer smoother action and better finish and plating on the metal parts.
Pen mills work well for most 7mm kits. As you work with other pen kits, or with more delicate pen blanks, you'll want to learn other ways of accurately squaring the blanks to length. (A disk sander with a right angle jig works well.) When using a pen mill, I use my bench vice to hold the pen blank. The mill is driven by a portable electric drill. If I want to, I can securely hold several blanks in the vice. Of course, I usually just hold one at a time. (The blanks need to be fairly uniform in size if you're going to hold several all lined up in the vice jaws.)
HTH
Re: Pen Turning Questions *LINK*
jeff Willaford
You'll definitely get good information here on WC such as David provided. Another excellent resource for pen turning is the IAP or International Association of Penturners.
http://www.penturners.org/forum/index.php
Steve Kniffen
Warren,
I'm a fan of friction finishes on my pens, but I've experienced the same thing you have on some of the pens I've finished with CA. Thanks for asking the question. I learned a lot.
On the topic of which slimline kit to buy, pick the ones that you like the finishes on. There is very little difference in the quality of slimline kits. There can be major differences between the quality on other kits. Most of the major kit suppliers sell quality kits and stand behind their work. For slimline, I like Woodturningz ( http://www.woodturningz.com/default.aspx ) because they have the largest variety of finishes available.
If you change suppliers, you need to make sure you buy the bushings for that kit from that supplier. A Sierra looks like a Wall Street looks like a Mesa looks like a Classica looks like a Gatsby looks like a Mesa, but each one is slightly different. Find one you like to make with the quality you want and stick with it. I buy different kits from different suppliers. If you want a list of what I like, send me your email via PM and I'll be glad to give you my recommendations.
My Woodcraft (Ft Worth, TX) sells a wooden pen vice that holds 2 pen blanks. It's relatively inexpensive, but a nice tool for holding blanks while you use a pen mill to square off the blanks while keeping your hand clear. I can't find it on the website so it may be a local product. Wouldn't be too tough to make if they don't have them there.
Enjoy, pen turning is addictive.
Steve
Bill Turpin in WNC mountains
I use a small cheap HF drill press to end mill my blanks. I hold the blanks with a pair of Channelocks. Flip the blank to do both ends. I use the same drill press to drill the blanks. The quill stroke is too short to get thru most blanks. Slip a scrap piece of 1" X under the blank to extend the hole, using the same Channelocks.
Terry Quiram
I use my drill press to mill the pen blanks. I hold the blank in a 4" wooden hand screw clamp. The mill guide rod centers the blank automatically. I also hone the long faces of the mill using a diamond hone to keep it sharp.
I have turned hundreds of slimlines. I only turned one using the stock center band. I make my own using Corian.
David...
Warren White
Thank you all for your considered replies. I will ask a couple of questions where my lack of experience shows.
"I shape me pens with a gentle curve and then chamfer the end (after the CA coat has been applied) using the long end of the skew. It also helps to separate the bushings from the blank. While my pen barrels are proud of the center band, the chamfer makes the transition look nice and it feels nice in your hand, too."
You chamfer the end AFTER the CA has been applied? How does this affect the polish of the CA glue? Also, I am afraid I haven't gone the skew route. I am using a Penn State Multi Bit chisel since I don't plan on investing in equipment to sharpen tools. (I know this will shock many, but I just want to keep my costs down.)
I liked your suggestion regarding milling the ends and I will try that. I wonder if you would suggest putting the blanks in a vise and using my small drill press.
Thank you again!
Warren
Terry....
Warren White
Thank you for your reply and your pens are BEAUTIFUL!
Would you lead me through the process you use for turning your own center bands? I really like the idea, but I have some questions. If you don't start out with thin material, where do you get material that is 3/16" thick? It would be great if there is a source of thin material, since I am not sure I have the skill to cut it cleanly and evenly enough to make it look as nice as yours.
Thanks again!
Warren
Jon Behnke
I'll add one point to the already good answers you've gotten, don't hold the blank with your hand when you mill the ends. If the blank were to blow out, split or spin it will chew up your hand. I use a bench mounted clamp to hold the blanks and a cordless drill to hole the end mill.
Jon
Warren White
Good advice, Jon. I have seen several videos where folks hold the blank in their hands. Seems like something bad waiting to happen.
I won't go into detail, but you know the little sign on the output chute of your lawn mower that says "Don't put your hand in here".....
Re: David...
David Walser
I wasn't familiar with the Penn State Multi-Bit chisel. It looks interesting. Not having handled the set myself, I cannot tell if you can use the diamond point detail bit to cut the chamfer. if not, you might be able to use the corner of the 3/8" square bit to make the cut.
The chamfer is very short and not very deep -- maybe 1/32" or less in each direction. As I said, I make the cut after I've polished the CA finish. With a sharp tool and a very light touch, I find that the resulting finish is very good. If need be, I simply make a very passes over the ends of the barrel with the micro mesh pads. Usually, I don' t bother with this step.
For pen milling, using a drill press in combination with a vice takes more time than the method I outlined. With the blank securely held in a vice, you can quickly adjust the angle of your hand drill to match the angle of the pen tube. This is quick and simple.
With the pen mill in the drill press, you can easily adjust the angle of the pen tube if you're holding the blank by hand (or using vice grips). It requires a little extra coordination since you need to use both hands (one to control the position of the blank and the other to lower the drill press quill). It's also quick and simple.
If the blank is securely held in a vice and the pen mill is in the drill press, you need to open the vice jaws enough to adjust the pen tube to match the drill press, tighten the vice, and then mill. Not as quick and easy.
HTH
Re: Terry.... *LINK*
Terry Quiram
I am fortunate to own a saw called the Hammond Glider. It allows me to cut thin strips from these small pieces of Corian. I glue the strips using med CA, clamp with cauls and leave to dry overnight. The strips are 1/2 inch wide. I mark off 1/2 inch squares and drill a 1/4 hole in each sq. I cut them apart on the scroll saw. The thickness is approx. 1/4.
I also save small cut off pieces of pen blanks to use for center bands.
Hammond Glider
Re: Terry....
Lloyd in Mississauga
Warren,
You may be able to get Corian samples from the hardware store in the counter top section. You can could also just use a different coloured wood as the band.
You can CA it to a face plate and turn them round and thin it out. multiple pieces can be glued together with CA to make multicoloured bands. Drill a 7mm hole in it and put in place of the centre bushing on your mandrel.
You may want to put a bit of paste wax on the sides so that your CA finish does not glue your band to the pen blank. You would turn the band down with the pen blank. When you apply the CA, some with stick to the corian and as you sand, the corian will sand with the blank.
I have not done it myself so far, so some of the details may need to be adjusted, but I think you get the idea.
Dont drill a
terry quiram
7mm hole it will be too large. Drill a 1/4 inch hole in the center band to fit over the mandrel and transmission.
Dick Coers
Milling the end is not a high speed operation. I've done hundreds with my hand. I have found that sanding is a much better way to do it. I bought the fixture to sand on a disc sander, but many put a sanding disc on the lathe headstock, a transfer punch of the correct size in a Jacobs chuck in the tailstock, then slide the blank up to square it.
Dick...
Warren White
That is an excellent idea. I will have to look into getting both items (a sanding disk that attaches to the headstock and a set of transfer punches.
Thank you for taking the time to respond.
Warren
