punky wood stabilization.
John Veerkamp
I have some slightly punky (end grain areas) in an English walnut bowl blank Which would be a better stabilizer rattle can lacquer or rattle can shellac? or is there any difference in the results?
Thanks
John Veerkamp
Thanks
John, IMO, rattle can won't work
GaryG in MD
unless you spray the whole can on. You need something that is going to really soak in, and that wood will act like a sponge. DAMHIK!
I would recommend that you use one of many liquid products, such as:
liquid shellac, if you don't mind it yellowing;
thinned lacquer or sanding sealer if you do.
You can also use commercial "wood hardener" products such as the Minwax version or "PC Petrifier".
I prefer a lacquer-based sealer because it doesn't change the color and because it can be top coated.
...GG
Re: punky wood stabilization.
Mike Stafford
I am going through the same problem with some wonderfully spalted hackberry. I have been using thinned lacquer based sanding sealer with great success. The sealer readily soaks into the punky areas, dries quickly and sands easily.
Whatever you decide to use make sure you thin it unless you buy a can of wood hardener off the store shelves which is already thinned lacquer.
jeff Willaford
If you're looking to stiffen fibers so you can cut without tearout in punky areas.... I've had great success with rattle can shellac AND a sharp tool. Multiple passes may be required. This works similar to using sanding sealer like Mike said.
If you really want to stabilize punky wood then that's a whole different ball game. I have no experience with that.
Dick Hines
CA will do the job, if there is not a lot of punky wood. Drip the thin CA on the wood and GTHOFTS. The smoke and fumes will be bad.
I would not do this if thee is a large area of punky wood.
kvaughan
Acrylic floor varnish has been successful with end grain on the local soft alder (not much for hard wood here).
I have thinned it 15% but did not see a difference.
I let it dry and recoat. Needs 24-48 hours to get hard- and hardens slowly for a few more days (but it is hard to wait).
Really sharp tools help.
Steve Worcester.
Technically, anything that gets put on the wood will only last as long as you are cutting the surface it penetrates.
So you have to keep spraying or wetting.
