The tree company that I am getting my wood from asked me if there was any way to dry log slices to make table tops. They have some logs that must be 4-6 feet across.
How in the world would dry something like that with out cracking?
Due to the different shrinkage ratio between tangental, and radial, cookies are hard to dry without checking. However, there are a few things which can give this some relief.
One is to bore out a hole in the pith, somewhere from 2" ~ 4", then take it slow. I'd suggest getting an appliance box to put it in, so it will dry more slowly.
Another way to get some relief, is to cut across at an angle, say 60º or less, rather than 90º. This gives the different ratios a way across from one face, then out the other. This method also needs to take it slowly too.
Then of course, there is Pentacryl, and PEG 1000.
Keep in mind, that none of these will have much strength, especially from sudden impact, so try to keep karate practitioners away from it. ha
Everyone wants to dry slices. I have a 32" soft maple slice in the garage that has a pie shaped split in it. The gap at the outside must be nearly 2" wide. That's a ton of shrinkage that folks hope won't happen to them. It's nearly a certainty it will.
We all know that it pretty close to impossible. However, if I was going to attempt to do it, here is what I would do:
Cut the slab WAY longer than your finished piece. Leave a foot or two on either end to crack and be cut away.
I would seal the ends to minimize the cracking.
If your slab comes from near the pith, you lose. Move it up in the tree diameter. It will be smaller, but you have a better chance. However, it will cup like mad, so make it thicker.
Since it will want to cup, you will need to weight it down. Substantially. I might even strap it down so that it cannot cup.
Lastly, I would attempt to do this in stages. It will need time. If you go too fast, you lose.
As you can see, I thought you meant cuts from the end of the log, which can be called Cookies, while Steve understands that to be "Slabs", cut longitudinally.
I think you may have misread the post. It appears he wants cross-section slices not lengthwise slabs. Your info for slabs is, as usual, right on. Cross-sectional slices, commonly referred to as "cookies", are much more difficult as I'm sure you know.
I got lucky with some white oak once-cut a bunch of 1" thick sections from a branch-some were about 10" diameter and some were about 7"-not one split in about 15 total pieces. They were from a 400 year old tree that is the symbol of the Landis Arboretum to which they were donated. No idea why they didn't split.
I was given a relatively dry, certainly under 21% MC, "slice" from a red cedar (Toona ciliata, syn. T. australis, Cedrela australis) approximately 125mm (5") thick several years ago. It is around 900mm or 30 to 32" dia & was already split then with a similar pie wedge crack almost 50mm (2") wide at the circumference.
Red cedar is pretty stable with shrinkage to 21% MC of 4.1% (tangential) 2.2% (radial), so there is not much hope for timbers with more radical shrinkage rates. 4% tangential means that for every 100 inches of circumference it will shrink almost 4". Not quite that bad in reality due to the radial shrinkage as well.
You could always be a crook and sell slices at 50% or better MC and blame the customer for "poor environmental conditions that caused the shrinkage."
A number of years ago there was an extensive discussion about drying cross-grain slices of wood for a table top. Dr. Gene Wengart participated. The final decision was to cut the slices into several wedges, dry and then fit them back together.
