Re: This may help, maybe!
Don Evans
Chuck:
Just FYI the brass thing on the rod is moveable. You can put 2 open end wrenches on the 2 places made for them and unscrew the right one off the other half (left part). This device is made for 7 mm rods to be used to take up extra room on a pen mandrell rod instead of using spacers.
Inside it is a compression washer (split ring) but it is what actually does the holding when the 2 pieces are tightened back together.
If you experiement with how much you tighten it and do NOT tighten more than necessary It will last much much longer. How? Screw the two halves together with minor snug and see if you can slide it on the rod with pushing on it to slide it up rod. Tighten more if needed.
It works like a water line compression fitting that has the brass rings in them. Pro plumbers still use those but I hate them for plumbing as I don't have to buy lots of the more expensive metal weave water lines.
You may know all about these brass things if so someone else on this group may get help from this.
It was Craft Supply, Woodcraft or PSI that had the brass things but I don't know if they are still carrying them. If you do many pen type things with the 7mm mandrel they are great to have and save lot of time. I have one with extra rings but don't use it much like I did 20 years ago.
Don PS -- if you take it apart be careful removing the white ring, use finesse removing it from the threaded brass part its just pressed into it due to tightening the two halves together and it is suppose to do that, fyi.
