Finish Problem
Finish Problem
Finish Problem
Ed Larson
I just completed a bowl and used my normal finish procedure of wipe on poly (4 coats) and beal buff (Trip, W dia and Wax). I then decided to add a microcrystalen wax and hand buffed with a lint free cloth. After adding the microcrystalan wax the bowl seems sticky. It was not sticky following the beal buff. Did I add too much Microcrystal wax. I'm thinking about buffing again on the lathe with a "dry" wax buff?? Any help appreciated. It's the first time I used a Microcrystalan and the bowl is a gift that needs to be finished by next week. The stickiness is not severe but is noticeable.
Re: Finish Problem
Re: Finish Problem
David Walser
Ed,
Microcrystalline waxes, like all paste waxes, are carried in a solvent. After the wax is applied, the solvent evaporates, leaving behind the wax. I suspect that the solvent in the microcrystalline wax softened the carnauba wax you had already applied. Another buffing with a clean wheel (no need to add additional wax) should fix the problem.
HTH
Re: Finish Problem
I'd wash it with mineral spirits first
Dick Coers
then follow David's advice. The carrier for those compounds is also wax. So you used a wax base, another wax base, then wax, then wax again. Using a buffing wheel on that mix is going to contaminant the wheel with the goo mix.
Re: Finish Problem
Re: I'd wash it with mineral spirits first
Barry L Elder
All good advice! Clean it down to the finish you used and then use only the museum wax and the less museum wax the better.
Re: Finish Problem
Solved Re: Finish Problem
Ed Larson
I rebuffed it and that solved the problem. I rebuffed before seeing the suggestions to use mineral spirits, I will remember that for next time.
Re: Finish Problem
Re:Hint on using micro wax
Don Evans
Ed:
I hope I can get u not to give up on that wax as it is great product and has a very good thing that others don't have. It doesn't show finger prints therefore your work stays clearer and looking better for long time.
I do want to add here that I have NO experience with wipe on poly so I don't know if that comes into this problem you had BUT, any finish MUST be cured before any type of waxing.
Here is what I think you need to practice on and I'm basing this ONLY due to the wording in you message....
All guesses on my part of course:
1. you used too much of this wax on the bowl, it is put on in thin layers ONLY.
and buffed by HAND with a clean cloth (old T-shirt works great, machine wash an old Tshirt and take it to the shop, keep it in paper bag to keep wood dust etc off of it. Take it out and cut up 4" squares of it and do not have any seams in that square. Now make another one of those but say 12" square, it is you buffing cloth.
I take the 4" one and with thumb and finger tips hold this small cloth and wipe it over the wax, it will get just a little of the wax on it but as you move the wax to the object and repeat this procedure the applicator cloth will start to work better with each use. At this point you should have a thin layer of wax on the object.
Take the 12" cloth (object will be sticky at this point) but it only take about 2 or 3 seconds of rubbing with the clean cloth in one area and you'll notice the object there is getting very slick.
Once the whole object is done and slick to touch note that you can handle it and it doesn't dull due to skin oil etc.
Now next thing that is great about micro wax is you can built it up. Once all the buffing is HAND done (I can wax and buff a 6" wide x 2 or 3" high bowl in about 2 minutes per layer of built up. Don't over do this couple of layers on a piece will last long time.
Now before doing anything go read the directions (again) on the wax) and you'll see I've said what they do but with some elaboration based on experience.
I think the biggest mistake most people do with this product and get turned off with it is applying to much at a time, a little goes a long way AFTER you have your applicator cloth conditioned. Store it in a zip lock bag and keep using the same cloth it will work better than an the very beginning, I think the cloth has to get it in all it's pores.
FYI one last hint: use a new tooth brush to buff out textured areas that the wax gets into where the buffing cloth will not touch the wax. Also a shoe buffing brush works on some areas but please buy a clean new brush for this purpose.
Being a carver and turner I keep new toothbrushes in the shop and use them a lot.
Let me know if you need me to clarify anything here I'm rushed right now and don't have time to double check this!
I don't have any stock in micro type wax sells :D
Don
Re: Finish Problem
Ed Larson
Don, thanks for your helpful hints. I will not give up on the micro-wax. I have been using the old T-shirt material for applying all my finishes and I used them with my micro-wax. One question, have you apply the micro-wax over canoba after beal buffing, I think that was the crux of my problem??
Re: Finish Problem
Don Evans
Ed, I think you should reread Barry Elders message above he makes it short, simple and accurate.
My understanding is that carnauba wax comes from vegetables, don't know what they are and microcrystalline wax is made from the sludge remaining in the bottom of pertroleum distillation tanks.
So cannot see how the two could co-exist separately, they would mix and become who knows what. What I know about the processes isn't much but above is what I've read on internet so it has to be right!!
Don
Re: Finish Problem
Using Ren wax over carnauba
Doug Wolf
Ed, I have been using the 3 Beal buff method for years and ALWAYS follow the carnauba with the Microcrystalline (Ren) wax. As they say a little goes a long way. I just touch my finger to the wax and rub the piece. Then hand buff. It has never dissolved the carnauba wax but does keep the shine longer with no fingerprints. I probably have over 100 pieces done this way.
