shop compressor
Dave Long
Any recommendations on small air compressor tp use around the shop and house.
shop compressor
Dave Long
Re: shop compressor
Bill Turpin in WNC mountains
I have a PC pancake. Six years of trouble-free service. It lives outside, gets occasional rain. It cost $150.
Re: shop compressor
phillip Medghalchi
Dave, get what you can afford and put it away as far as you can from you.
Re: shop compressor
Dale Miner
I am not a fan of the direct drive or the oilless types.
Re: shop compressor
Keith Newton
Rolair JC10 1 HP Oil-Less Compressor with Overload Protection and Low RPM for Quiet Operation.
I like this brand, having had one for 30 years in constant use, with zero problems. This one is really quiet, which makes life more pleasant than most small units.
Re: shop compressor
Ric Taylor
I have a Rolair JC10 that works great for me. It is very quiet and doesn't take up much space. There are several YouTube videos out there that demonstrate what the compressor can do, and also show that you can stand right next to it while it is running and carry on a normal conversation.
Ric
Re: shop compressor
phillip Medghalchi
Can, can you share with us about your use of this, like for blowing the dust off, spraying paint, varnish, guns, and how often this is running constantly? Most I am aware of kick in as soon as there is a ltil discrepancy in the set up pressure and the use pressure and they are loud. You say this one is quiet, at what cost or what are you compromising Vs. the bigger brother versions of this one?
Make a List
Of whast you want to do with air and air tools.
Spritzing off dust?
Driving nails?
Spraying finishes?
Changing your truck's tires?
Running a sander of some sort?
Then go look at the tools you want to connect (spray gun, drill, sanders, grinder, impact wrench, etm) and see what "SCFM" [standard cubic feet per minute] they require.
Small 1 hp units will run an air squirt for dusting or a nail gun, but not an impact driver or sprayer. Sanders take big air, 12- 24 scfm.
I have two. A stationary 12 scfm 60gal unit and a 5 scfm portable. They serve very different functions.
BTW I don't bother trying to drill holes with an air drill; waste of time and money.
Re: shop compressor
William Duffield
Keith,
Thanks to your recommendations, I now have the Rolair JC10 in my shop, and my bench dog is much happier than when I was using the extremely loud PC 2002 compressor. Other than the dB levels, I was quite happy with the PC, but I am more than pleased with the very quiet Rolair.
Note that neither of these compressors has enough capacity to run a die grinder or a sander, except in burst mode, but they are quite sufficient for inflating tires (and basketballs and volleyballs
) and for chasing dust and spiders and other cleaning tasks, and for driving finish nail guns, brad guns and pinners. I don't think they would keep up with a framing crew or a roofing crew.
Re: shop compressor
Keith Newton
Hey William, glad to hear you and your dog like it. I wish that I had bought that one, but at the last moment thought I might need to use it with a framing gun, and hit the 2hp button. That was not the best choice, since I have four others that could go out to jobs when I need more capacity. AActually, I think I suffered a momentary "Tim the Tool-guy bigger is always better" macho syndrome. Good thing they didn't offer one with a big Harley Davidson sound, or I'd probably have gotten it. Ha
Re: shop compressor
William Duffield
I still laugh every time I think about Tim explaining how he fixed his garbage disposal by hooking it up to a Harley engine.
I don't have a framing nailer, so I cant test my compressor for number of nails per minute. If anyone is interested in matching a particular compressor to a particular tool, searching Amazon will provide the PSI and CFM specs for most of them. They will allow you to calculate whether your compressor will keep up with a particular tool.
