After using my lathe for a while, I want to raise it between 1" - 1 1/2" higher.
I have a Nova DVR with the cast iron base. Is it safe to place a board at each end under the feet to raise it? I was thinking of oak, but I also have some black locust I could use. The floor under the lathe is tile on top of concrete.
I also have to think how to arrange it so I don't trip on the boards.
At 6 ft 4 in my PM was a little low. I jacked it up on 4x4's. I also built a a box around the feet the keep the lathe on the blocks if it started to vibrate. This makes my lathe to high for the normal person to use. Then I never said I was normal.
keith, I was looking for those all over the place and can not find them in San Antonio, I was wondering if you can remember where you got yours. I fixed mine, but it's not vibration free, so when i have something of good weight I worry about the vibration.
Tim, zi think this can be overcome if you get the anti-skid spray from your local hardware store or automotive and spray the underneath the blacks to avoid skidding. I hope.
Jaime, his problem is that there are slick tiles on the floor and what is he going to do with the slick board start walking on the tile once he has a heavy blank on the lathe? Doesn't e have to put some kind of rubber under neath to avoid the vibration and walking?
....tire innertube lying around? I guess the tubeless tires have made those hard to come by, but a good sized rubber mat would be good for your feet as well as the lathe feet! If you have a Tractor Supply or other horse supplier around, check out the horse stall mats made of recycled tires.
My PM is on two layers of 6" x 6" x 24". I am 6'6". The 6 x 6 are held together with 10" x 1/2" lag screws. Dimples are cut into the top layer to keep feet from slipping off. The two stacks have a center mortise and tenon joint for a 2" x 6" that forms the crossbar that holds the I-----I together This has NEVER vibrated in 5 years. Cut the half of each mortise before fastening the 6 x6 together. What is needed: one 6" x 6" x 8", one 2" x 6" x 8', 4 each 1/2" x 10" lag screws, 4 each 3/8" x 8" lag screws. Adjust board thickness to suit your height. If you make one fullsize, do not allow one human to try to pick it up.
I needed to raise my Jet 1642 because I'm 6'3 and bending over it was killing my back. I took an eight foot 2x6 from Lowe's, cut it into four 2' pieces, fastened them together into 2 pairs with lag screws, and mounted them to the base through the holes where the adjustable feet were before with more lag screws. This added height and stability. The wood seems to dampen vibration, too.
