Have a question? Ask Woody!
my $20 HF grinder finally died
I bought this thing on a whim thinking I might find it useful. It's been incredibly useful and I have hundreds of hours on it, grinding and carving wood and metal. I figured if I really used it I would buy a better grinder and I did. I bought a Makita on sale at the hardware about 5 years ago. I hardly use it. I like the HF better. It was noisier and probaby doesn't have the power but you can't rotate the blade guard which I liked on the HF model.
Oh well, everything must come to an end. I thought about burying it in the backyard with a small cross. Naaaah. I'll just have to learn to use the Makita. Maybe HF will have another sale.
Re: my $20 HF grinder finally died
Steven Antonucci
RIP HF Grinder...
phillip Medghalchi
John, i am looking at the inside track sale flier and they have it form 7" heavy duty for $44.99 to 4 1/2" for $14.99 , In most cases when I go there I google the coupon and right on the spot I get another %25 off it, so you may want to try it. If you want I can send you the coupon on your phone. I think if you got that many years out of it then you got your money's worth.
Phillip the funny part is I liked it so much I bought another one about a year later and it burned up the second time I used it. I may give another one a try sometime when I'm at the store and can look at how the guard worked. When carving with it I like to rotate the guard and use that as a bevel to avoid kick back. Can't do that with the makita because it's in a fixed position. In fact I had to remove the guard last night when cutting a weld because it was in the way. I could have simply rotated it on the old Harbour Freight.
Don Leydens
Don Leydens
I bought a HF grinder and it burnt up in less than 2 minutes. Got it replaced and that one burnt up in less than five minutes. Finally bought a Dewalt and can't kill it!
phillip Medghalchi
John, I haven't had the HF one, but I have the Makita you are talking about and at times I had to take the guard off and be very wary about applying it to work. I may have to look into the HF myself, but the mainn point was to remember right before you go to the cashier to pay, I pull up HF coupons and if I have two to more items then I pay different times to get those 25% discount and that way I don't feel twoo bad throwing them away. I have been having trouble buying items recently that someone else bought and took soem parts out of them and returned them to the store and store restock them. so, when I get them home they have missing parts in them, which makes me take another trip.
phillip Medghalchi
don, I think with HF nowaday, is hit or miss. i have had that happened to me on few tools I bought that I knew are not going to be used that much, and sure enough they went out quickly and luckily I got then replaced within that 90 day in store replacement policy. Now, if they go out next time I go to use then, I am out that money even though they might be new. Oh, well, goes back to the previous discussion of Chinese made products for what we use. that good old saying," you get what you pay for?" then I guess that can be justified that when you are in the midst of your work at 9:30 pm and it goes out do you really want that mental momentum of creativity to dye with a failure of your tool?
