Peeling cut versus Planing cut
Dale Bonertz
What is your definition of them? I hear some say picture peeling and apple where you drop the handle and slice the skin off. Makes sense so in lathe terms some call that a slicing cut or shearing cut. But you peel a potato which is more in line with what I would refer to a planing cut since a potato peeler action is much like a block plane action thus planing cut or is it a peeling cut? So what do you folks like to relate them to and how do you compare them with the current terminology used in wood turning (roughing cut, pull cut, push cut, slicing cut, shearing cut, shear scraping and etc.). I am just trying to end some confusion, at least in my mind.
Re: Peeling cut versus Planing cut
I've always heard those terms used mostly when describing the skew and its probably easiest to understand. I think of a paring cut as the cut I use to make a tenon on a spindle This is similar to using a parting tool the cutting edge is parallel to spindle and the wood is coming over the edge at 90degrees. Lay the bevel on the wood and lift the handle to make the cut.
What I call a planing cut is typically a normal cut with the skew where your cutting along the length on the spindle and the wood is being sliced off at a skewing angle.
Dick Coers
Peeling cut is made without moving the tool along the rest, planing cut is moving the tool parallel to, and along the rest.
David Walser
A peeling cut is a bevel rubbing cut made by holding the cutting edge at 90 degrees to the lathe's direction of rotation. This "peels" off each layer of wood and is the way veneer is made for many types of plywood. A peeling cut removes a lot of wood very quickly. Properly done, it leaves a good surface (better than that left by scraping) requiring little sanding. A skew can be used for a peeling cut. But a spindle roughing gouge is almost always used in peeling orientation.
A planing cut is a bevel rubbing cut made by holding the cutting edge at about 45 degrees to the direction of rotation. This slices off the wood. Properly done, it leaves a very good surface (better than that left by a planing cut) requiring little sanding. Skews are often used in planing orientation, but spindle gouges and bowl gouges can also be used for planing.
HTH
Steven Antonucci
I agree with your assessment...but...
steven antonucci
I also use a spindle roughing gouge in "planing mode" frequently because of the better surface and because I can stand behind the cut and not get a face full of shavings.
S
Re: I agree with your assessment...but...
Ditto I often find the spindle roughing gouge will flex a long thin spindle less than a skew. It has to be sharpened differently than they come from the factory. I sharpen mine at 35 degrees. I also have a small flat spindle gouge that I use for the long thin spindles. I use them both in planing mode.
I associate the peeling cut only.......
JamieDonaldson
...with spindle turning, generally done with a skew or bedan, at 90 degrees to the rotation of the wood, such as preparation of a tenon. I do planing cuts with many tools, including bowl and roughing gouges, again mostly when spindle turning.
Keith Tompkins
Keith Tompkins
Wanna' have a little fun and impress your turning buddies? Find a piece of green wood, say a piece of a branch 5" diameter or so. Mount it on the lathe with the centers right on the pith.
Do a peeling cut with a gouge or skew, and watch the continuous ribbon of wood come off the tool. Just keep raising the handle! With a little practice, you can aim where the ribbon goes!
