New Battery for Airstream
Steve Criscenzo
I have been using an Airstream helmet / respirator for almost ten years and have it on most times I am working in the shop. A few years ago the nicad battery pack had reduced run times but the $200 + cost for a new battery put me off. I thought about having it rebuilt but fortunately, about the same time there was information here on this forum about converting to a Tecna electronics battery. I converted the unit to a USB plug and have been using the Tecna battery since. It cost about $50 and is much lighter.
Well the Tecna battery is showing it age and I could not get a full day of use. The Tecna battery is no longer made but I found one by Anker on Amazon for $26 that has 10,000 mA hrs and 3 amp output. Fully charged it has over 8 hours run time. It also has LEDs to indicate remaining charge. Down side is that it is a bit bigger than the Tecna (but much smaller than the original nicad pack) and there is no switch so you have to unplug it to turn off. I was a bit worried that it labeled a "smart charger" but for $26, figured I would give it a try and if it did not work, I would use it a backup power for other small electronics. So far however it seems to work fine.
Seems like 3M could use this battery technology to reduce the cost of an otherwise great unit.
Steve
Re: New Battery for Airstream
Alan Zenreich
Alan Zenreich
It's unfortunate that Tekkeon no longer makes the particular model of battery I showed in the video. Their replacement model doesn't have enough power to start up the fan in the helmet.
However, just about any usb battery that will power an iPad should work. So look for any usb battery rated at 2 amps or 10 watts. As you mentioned, some batteries, like the Tylt PowerPlant, don't have on off switches... So I added a simple slide switch in line with the connector on the helmet.
